06-10-2015, 04:17 PM | #1 |
Replacing wiper motor...difficult task?
My wiper motor has burned out I guess, stopped working and makes an awful buzzing sound.
Anyway, truck is my daily right now so I need to replace it. Is this a difficult task and what else do I need to look at while I'm at it? Any seals, etc. 1972 GMC Looks like a pain in the ass so I'm just prepping myself. Thanks
1972 GMC Sierra LWB (Aquafresh) 1962 Cadillac Convertible 1962 Cadillac Sedan project |
06-10-2015, 04:37 PM | #2 |
Go Pack Go!
Re: Replacing wiper motor...difficult task?
3 screws hold it to the firewall under the dash along with electrical. Some clips hold the linkage after you take off the cowl.
06-10-2015, 04:41 PM | #3 |
It is more difficult if you have AC because of all of the hoses taking up space under there but removing them is easy and once done you can get to the motor easy.
1971 Cheyenne Big Block Longhorn |
06-10-2015, 04:57 PM | #4 |
It wood b best to first try lubricating the linkage and include the wiper towers to see if it is just bound up due to 40years and seeing no maintenece
06-10-2015, 05:49 PM | #5 |
It's brutal with AC. It was the #139th thing I took off my truck, and about the 20th thing from the interior, so it's well buried. If you can get away with lubricating or something, do it. Otherwise plan a solid day I think to do it right.
I'm particularly bitter about it because my wiper arm linkage was installed backwards, and it -almost- works that way, but binds. So I spent a lot of time thinking I had done something wrong with the motor...
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
06-11-2015, 11:20 AM | #6 |
Thanks all, looks like I'll plan for a weekend project.
06-15-2015, 09:57 AM | #7 |
Wow, what a PITA that was last night! Getting those 3 screws back was just about the most difficult thing I've done on this truck. But now I have working wipers again, not sure but the motor that I pulled out looks original.
06-15-2015, 03:51 PM | #8 |
So how did you fix it? Clean and lube or replace motor?
03-11-2018, 10:40 PM | #9 |
Been there, done that with AC. It's not a PITA it's a ROYAL PITA!
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
06-15-2015, 05:37 PM | #10 |
Replaced the motor, it was shot. Bought a rebuilt one and swamped the pump over.
Ended up having to take my ignition switch out in order to have a straight access to the top screw.
06-15-2015, 05:43 PM | #11 |
Wow, you did have a job there!
My washer has not worked since 1990, when the truck was painted. They painted over the nozzles so that may be all that is keeping it from working. I'll find out soon (I hope). |
03-11-2018, 07:31 PM | #12 |
Does anyone have a picture of where the wiper motor is under the dash? I can't seem to locate it. The emergency brake on my '67 is not helping the view much.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
03-11-2018, 09:21 PM | #13 |
Look through the cowl vents for the bolt that holds your linkage to your wipers. It is right there on the inside. Sort of on the fuel gage side of the radio up high.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5 |
03-11-2018, 09:25 PM | #14 |
Here is a view of mine as viewed through radio cutout. It has the wrong washer pump attached to it. Second picture is of the new pump and the OE pump off the wiper motor.
Plus a thread to maybe help some more. http://67-72chevytrucks.com/vboard/s...d.php?t=695112
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
