Old 06-10-2015, 10:46 PM   #1
Liltroy
Liltroy's Avatar
4L80e wiring help
I'm got my wait4me harness back today and I'm really confused about the wiring on my transmission.
First off, these are the only transmission connections on the harness
and this one yellow wire, mixed in with a bundle of unlabled wires. I dont know what to do with any of them....even the labeled one!!!
so that still leaves the plastic gear position thingy on the side of the trans to deal with. there are no wires in the engine harness that connect to it so what do I do about that? doesnt the ecu need to read that module to know what gear its in and things like that? I'm REALLY confused and would greatly appreciate any and all help!
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac
Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303
My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw
Liltroy is offline   Reply With Quote
Old 06-11-2015, 12:12 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 4L80e wiring help
The gear position indicator isn't a needed function to run the truck. All it does is tell the BCM what position the gear lever is in so it can be displayed on the heads up display. The trans stuff you have should be the main connector for the solenoids etc, then the ISS and VSS.
The labeled wire says "park neutral position switch" if I'm filling on the blanks I can't see correctly. This should most likely be the wire that connects to the switch thats on your shifter. Its a safety measure, but not a bad idea to hook it up if you can.
I have no clue what all the unlabeled stuff is. I suggest you call whoever did your harness and ask them. No way for us to know for sure. Usually the only wires on a swap harness that need to be physically terminated are constant or switched 12v powers to various places like the fuse box, starter etc.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-11-2015, 08:39 AM   #3
Liltroy
Liltroy's Avatar
Ok so I don't need anything to plug into that box on the selector shaft. Can it just be removed from the transmission then?
I thought that's where that neutral wire went so thanks for confirming that for me. I'll call Jesse today about the others and thank you so much for the help!
Old 06-11-2015, 08:49 AM   #4
Shon
Did you happen to call wait4me? if not, why? if so, what did he say?
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 06-11-2015, 09:32 AM   #5
Liltroy
Liltroy's Avatar
I'm gonna call him today. I just got the harness late last night. I'm at work right now.
Old 06-11-2015, 02:39 PM   #6
boostedc10
boostedc10's Avatar
LilTroy you are correct the switch on the shift shaft contains the neutral safety switch. Also for the 4l80 you should have one more of the connectors on the left in your picture. The 80 has both ISS and VSS on it. One more thing that needs to be changed is the position of a few wires in the round connector.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 06-11-2015, 02:42 PM   #7
boostedc10
boostedc10's Avatar
Here is a thread I did a while back that may help you out.
http://67-72chevytrucks.com/vboard/s...d.php?t=642560
Brandon
Instagram: DRVFSTR
Old 06-11-2015, 03:24 PM   #8
Liltroy
Liltroy's Avatar
So I just got off the phone with Hannah at wait4me performance. First I have to tell you she was very cheerful as well as helpful.
The marked wire is the neutral safety and is the only wore required in that group. It can either be run to the black box on the side of the transmission for a neutral signal OR can simply be connected to the neutral safety switch on my b&m shifter. The reason it wasn't run to a plug is because I had informed them when I sent it in that I had not yet found the transmission I was going to use and the 4l80 up to 2004 had a two plug setup whereas the 05-up have a single plug so they didn't know which I would need. Turns out to be a good thing since I'm running a ratchet shifter with the neutral switch on it, I can just get rid of the MLP sensor on the side of the transmission all together and not have that extra harness under there.
Old 06-11-2015, 03:28 PM   #9
Liltroy
Liltroy's Avatar
Boosted, the iss and vss connectors are both in the pic. The one on the left just has the outer part broken off.... I'll be replacing the plug. And it was already pinned for 4l80e to begin with.
Old 06-12-2015, 02:21 AM   #10
Liltroy
Liltroy's Avatar
Already covered this.
Old 06-12-2015, 01:33 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thats whats weird tho...I can't find a picture of the shielded square plug as a VSS. Every replacement part I can find is the small open two-prong plug. So I feel like its messing with my head. I looked at probably 20 harness layouts.
Old 06-12-2015, 01:40 PM   #12
dayj1
Agreed. On some 4x4 applications, there is a short VSS jumper harness that goes from the transfer case to the main harness, but I can't remember if it has a plug like the OP is showing in the pictures. Maybe the harness pictured above is from a 4x4 application.
dayj1 is offline   Reply With Quote
Old 06-11-2015, 03:37 PM   #13
boostedc10
boostedc10's Avatar
Usually the ISS and VSS connectors don't have a hard shell like on the right. Is it an older 80?
Brandon
Instagram: DRVFSTR
Old 06-11-2015, 04:43 PM   #14
Liltroy
Liltroy's Avatar
the trans is a 2001. the harness is a 2006. Im actually going to change the connectors out for the ones that came with the transmission since one on the harness is broken anyway.
Old 06-11-2015, 08:40 PM   #15
aknovaman
They built your harness and sent it back with the trans wiring all dirty. Really?
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 06-11-2015, 09:39 PM   #16
Liltroy
Liltroy's Avatar
Unhappy Re: 4L80e wiring help
The whole harness looks like that. Check out my build thread for details
Old 06-12-2015, 01:59 AM   #17
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The oddball square connector has a label on it...what does it say? If its not a VSS/ISS, then that harness only has one...meaning it was set for a 4l60e, or a 4x4 4l80e
Old 06-12-2015, 03:08 PM   #18
Liltroy
Liltroy's Avatar
All I know is its got the right wires in it and it plugs in. The inner plug is the same...just with a different outer piece but I'm wanting to switch it out for the ones on the transmission I bought.I'm just not sure how to take these plugs apart without breaking them??? Anybody got that knowledge for me?
Old 06-12-2015, 03:52 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Weatherpak connectors usually have a couple "tabs" that let the plug snap apart and reveals the little terminals where the wires attach.
If its Molex (where there is like a dried epoxy holding everything in place, then you have to cut them off and wire a new one on.
Old 06-12-2015, 05:31 PM   #20
Liltroy
Liltroy's Avatar
That's how the plugs currently on the harness are.... They unsnap at the back but the ones on the transmission don't. That's why I'm stumped. Pep boys sells weather pac connectors but didn't have any that small. I looked earlier when I was buying wire loom. So much drama for such a little thing..... Kinda like my wife lol.
Old 06-12-2015, 06:28 PM   #21
Liltroy
Liltroy's Avatar
Ok apparently they just push out the front
Old 06-12-2015, 06:36 PM   #22
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Old 06-12-2015, 08:52 PM   #23
Liltroy
Liltroy's Avatar
Old 06-12-2015, 10:11 PM   #24
aknovaman
Check your pm.
FMCDH GBU and GBA
Old 06-13-2015, 08:56 AM   #25
Liltroy
Liltroy's Avatar
Check your pm.
Thank you for the help. After talking to Hannah at wait4me performance, apparently I was missing the vss connector on my harness so she replaced it with what she had laying around. It's the right plug,just has a weird lock shell, however, that set of wires only needed to be about five inches long. The transmission I bought has those connectors still on it but the vss sensor one only has about 1/4 inch of wire sticking out so I had to take it apart and I'm now searching ford my solder iron join wires together to connector. I will be shortening the harness a bit as well.
Thanks for all the help gentlemen..........oh and you too aknovaman.
