06-11-2015, 09:34 PM | #1 |
How to fill molding holes
Figured I would try and contribute something to the forum for what it's worth. I'm doing this all from my phone so it may or may not work! Lol. I work at a hot rod shop in Denver, and this is how I fill up molding holes.
Here is the hole we're going to fill. This is on a Plymouth fury. Using a scotch Brite roloc I prep the area and drill it out slightly bigger to fit the plug we're going to use to fill it. This is the punch I use to make the plug The punch creates a divot in the plug. I set it on an anvil and tap it with a hammer to flatten one side. There will still be a small divot on the other side. This is the side that goes out. I use a piece of tape on the backside to hold the plug for a quick tack. It does burn the tape, so be quick. One quick take. I remove the tape, then using a hammer and dolly I will tap the plug and get it flush. Next it's welded up. I tig weld, but mig or gas is also acceptable. Just remember when mig welding it will be hard to hammer and dolly to a metal finish. The mig welding wire is harder then the surrounding metal and is prone to cracking. Remember that divot in the plug? Put a little tack on top of that to fill it up. I do this because I found when putting the plug in the other way the metal got way too thin in this area so I like to fill it up with weld. Next I use a 60 grit roloc to knock down the weld. I don't take it all the way down, notice you can still see we're the ends of the weld are. Next I will planish out any distortion with a slapper file and a dolly. Then finish with a scotch Brite roloc. |
06-11-2015, 09:41 PM | #2 |
Re: How to fill molding holes
Nice work! I have heard of this slapper file thing but have never seen one. Could you post a pic?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
06-11-2015, 09:46 PM | #3 |
I'll try to remember when I get to work tomorrow. I made it, just a flat file with 2 bends in it. It's used in place of a hammer. Just a personal preference. The file will put little marks in the steel and you can see where you low spots are. (The areas without marks)
06-11-2015, 10:31 PM | #4 |
Good work. These type of threads can be too far & in between sometimes. Thanks for taking the time to share here.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
06-11-2015, 11:32 PM | #5 |
That is a new one for me. I will have to try that.
06-12-2015, 12:10 AM | #6 |
I am taking classes in Automotive Restoration at a college in Kansas. Our sheet metal professor told us about slapper files, but he himself uses small body shop hammers. I will be graduating this next spring ('16) and will be out on my own working in a shop. I too would like to see what you have used as a slapper file.
White70C20 1970 Blue C20 - 250, 4 speed 1985 Ford Thunderbird 2005 Pontiac G6 |
06-12-2015, 07:02 AM | #7 |
Very nice work, thanks for sharing...
06-12-2015, 07:32 AM | #8 |
I saw that technique in a Ron Covell video. MIG doesn't work as well because the wire just pushes the plug out of the hole. TIG works though.
06-12-2015, 08:23 AM | #9 |
For those who don't have a punch to make the plugs, Ron Covell sells an assortment of plugs of different diameters for that purpose. Saved me a bunch of time trying to make them when filling firewall holes etc.
06-12-2015, 08:25 AM | #10 |
nice and simple approach =0)
dont want to hear excuses, i want to hear solution(s) |
06-12-2015, 11:21 AM | #11 |
Location: Formerly MD and San Diego, now loving life in Arizona
Much better than what a PO did to the bed of my '71 GMC. That PO used a ballpeen hammer on every hole and then filled each crater with bondo. So much damage done that it was cheaper to get a replacement bed.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
