06-15-2015, 10:13 AM | #1 |
Eaton HO52 axle tube width
Anyone know the witdth of the axle tubes on an Eaton HO52? I'd like to order some new spring perches today but I don't have the axle in front of me to measure it myself. Thanks.
06-15-2015, 10:43 AM | #2 |
Re: Eaton HO52 axle tube width
Do you want the axle diameter? Or distance between the perches?
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
06-15-2015, 10:59 AM | #3 |
I need the axle diameter. I'm sticking this axle under a 1/2 ton truck and apparently the 3/4 ton it came from had the spring perches a little closer to the pumpkin.
06-15-2015, 11:04 AM | #4 |
Okay, I'll check and get back to you a little later.
06-15-2015, 11:26 AM | #5 |
Outside diameter of the tube is 3.25".
06-15-2015, 11:41 AM | #6 |
Thank you sir, I appreciate it
06-15-2015, 01:02 PM | #7 |
No problem.
06-17-2015, 01:02 PM | #8 |
I guess I do need the distance between the perches as well, just to be sure. My frame is from a '71 k10. Anyone know the distance between the leaf spring perches on a 1/2 ton?
06-17-2015, 03:05 PM | #9 |
20' Daredevil (Ret)
My '72 K20 measures 40 1/8" on-center. Should be the same but probably better confirm it. Someone should chime in here.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
