Old 06-15-2015, 02:24 PM   #1
409impala1
69 GMC c15, leaf spring
I have a rear left broken leaf spring, does anyone have one or what can replace it. probably put on a set of them.
409impala1 is offline   Reply With Quote
Old 06-15-2015, 03:03 PM   #2
hugger6933
Re: 69 GMC c15, leaf spring
Have you looked at any of the squares springs?[73-87]. I have a line on a 72 GMC short bed for salvage, It probably has the leafs as it didn't look to be hard loaded just a regular truck. The leafs were standard on the GMC and optional on the Chevrolet. It was just backwards from the Chevrolet that had standard coils with optional leafs. Jim
hugger6933 is offline   Reply With Quote
Old 06-15-2015, 03:44 PM   #3
Matt Cramer
Might want to try contacting these guys.
http://www.springsnthings.com/index.htm
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 11-04-2015, 11:01 PM   #4
409impala1
What rear springs will fit this? I am dire need of help. thanks
Old 11-05-2015, 09:20 AM   #5
Mike C
Mike C's Avatar
The two wheel drive 69-72 trucks use 2 1/4" wide springs (except the Longhorn and probably the C30) while the squares use 2 1/2", so that is out.
Eaton-Detroit can build you stock replacement springs or you can get drop springs from places like Early Classic Enterprises. The other option is to find a parts truck with 2 1/4" leafs. C20 leafs will physically fit but have a higher spring rate and different ride height.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
