Old 06-17-2015, 04:55 PM   #1
chad75
chad75's Avatar
Door inner/Outer scrapers
I purchased some new Inner/Outer window scraper seals for my 72 Jimmy. I have never changed these, anyone have any tips? Finishing all the small things a little at a time. Thank you in advance, Chad.
chad75 is offline   Reply With Quote
Old 06-17-2015, 05:25 PM   #2
hemi43
hemi43's Avatar
Re: Door inner/Outer scrapers
I've put quite a few of these on the old Mopars, and they install the same way on our trucks. Put a piece of masking tape on the edge so that if you accidentally touch the paint with the edge of the clips you wont scratch anything. Those clips are sharp on the edge.
Line up all the clips in their corresponding holes before pushing them in. This will prevent warping the scrapers.
Dan
hemi43 is offline   Reply With Quote
Old 06-17-2015, 05:27 PM   #3
chad75
chad75's Avatar
Good idea on the tape, they just pop out like a trim clip? Thank you
Old 06-17-2015, 07:45 PM   #4
jobrla
Hi, I have also replaced a lot of these. Use a seal clip tool to remove old ones. Once they are all out make sure none of the door clip slots got bowed out. If so, bend them back straight. When installing, you will find that depending on the brand, you may have to trim a small amount of rubber on the outer seal where it passes the wing window
jobrla is offline   Reply With Quote
Old 06-17-2015, 10:42 PM   #5
chad75
chad75's Avatar
Thank you, I will report on the installation.
Old 06-17-2015, 11:31 PM   #6
Blazerowner
Blazerowner's Avatar
They are a bit stubborn to remove. I had my glass out when I replaced mine because I was putting in all new weatherstrip. Made it easier to get them out.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 06-18-2015, 08:50 AM   #7
tjsblazer
tjsblazer's Avatar
Haven't done it myself but great looking truck !
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 06-18-2015, 06:25 PM   #8
Chulisohombre
Chulisohombre's Avatar
I have new ones for mine but haven't tried tackling this one yet either. Sounds fairly simple. The ones on my impala had pop rivets to
Install them. Was much more involved.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 06-19-2015, 12:06 AM   #9
Blazerowner
They pretty much grab the sheet metal. It will prob be pretty hard to remove them with the glass in. They are easy to pop in but they are designed to grab and stay in. The clips can bend the sheetmetal when you try to remove them.
Kirk
Old 06-20-2015, 02:27 AM   #10
chad75
chad75's Avatar
Well, I received the scrapers this afternoon but it was a Lil toasty 109 so i waited till it cooled off after the sun went down. I can report a very easy install inner and outer alike! looks awesome and should have been done sooner but such as life!!! Thanks again for the experiance and I will ad mine as I can
Old 07-06-2015, 04:14 AM   #11
robs71k5
K5drive
robs71k5's Avatar
Has anyone else had an issue with these seals ? I gave after market doors and the seals don't mate with the glass and therefore when it rains the water goes inside the door . The doors I purchased are suspect because the vent window on the drivers side isn't high evough either and that seal won't fit . But wondering where to order a new pair of doors that are more accurate
robs71k5 is offline   Reply With Quote
