06-18-2015, 08:58 AM | #1 |
What year is my truck?
The title says 1960 but I feel like it's a 62!
06-18-2015, 09:02 AM | #2 |
Re: What year is my truck?
pics
06-18-2015, 09:13 AM | #3 |
1966 Crew Cab & 4X4 Fanatic
What is the vin number and does it match the number on the frame on left side located on top of the frame about the front of the engine?
06-18-2015, 09:27 AM | #4 |
Here is a decoder. Sorry I cut it off but you can check your first number and see what year it is. I hope this helps you.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
06-18-2015, 09:48 AM | #5 |
numbers
06-18-2015, 09:48 AM | #6 |
Has the wrong year hood on it for sure. That hood is from 62-66. That's a common swap. Yours is either a 60 or 61 due to the double headlight grill. 62 had single head lights and "oval pod housings" for the headlights.
EDIT: Checked the vin...you have a 1960.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
06-18-2015, 09:52 AM | #7 |
But I think the emblem on the cowl extension is a 62, right? So did they change that out as well? Maybe they added it when they repainted it.
06-18-2015, 09:56 AM | #8 |
Those are 62 emblems. 60 emblems are fairly tuff to find I think. They make 1/2 ton ones brand new. What's yer plans for it? What ya got for a drive train?
Another thing I noticed...that is not an all original truck. According to the vin decoder your cab vin states its a 1960 1/2 ton shortbed 2wd. Looks like someone has done a cab swap in the past.
06-18-2015, 10:07 AM | #9 | |
06-18-2015, 10:19 AM | #10 | |
06-18-2015, 09:55 AM | #11 |
According to the decoder it's a 60 because of the 0 in the vin. Like TJ said, you have a 62-66 hood and 62 badges on the side. If you want to go back to the original look you won't have to change much. I still thinks it a cool truck! Whats your plans?
06-18-2015, 10:21 AM | #12 | |
Now that I know it's a 60', I'm going to change the emblems and add some better mirrors and stock wheels and hub caps and DRIVE THE CRAP OUT OF IT!! |
06-18-2015, 10:39 AM | #13 |
The frame number does not match the cab vin tag it should be stamped J104591 the cab was put on this frame at some point. The cab vin tag looks to be original and not altered, it says it is a 1960.
06-18-2015, 11:36 AM | #14 |
Also forgot to mention the cab is from a 2WD drive truck. The original 4x4 cab must have possibly been wrecked or badly rusted.
06-18-2015, 11:49 AM | #15 |
06-18-2015, 12:59 PM | #16 |
frame looks like my 61. 60-62 frames are the same. they changed the front shock mounting in 63? maybe late 63. rear shock mounting also, don't know what year. (ron you out there)about the vin the c would be a k if the cab came off a 4x4.
1961 chevy K10 my build is------------61K10 build |
06-21-2015, 10:36 AM | #17 | |
Ok, here comes one of the stupidest questions ever, how do I shift into 4 wheel drive? I know I need to first turn the front hubs but what does the shifter do? When I turn the hub actuator, which arrow should the bar be pointing towards? |
06-18-2015, 02:44 PM | #18 |
Check The Champ, Demonstrator
According to the preliminary information booklet, the 4wd lever was on the passenger side of the 4 speed shifter, 1962 was on the drivers side of the 4 speed shifter.
Napco's 4WD were on the right as well.1960 was the first year for GM in house production of light duty 4WD in 1/2 and 3/4 tons, no 1 ton 4wd were produced by GM The Vin should have a K as a model designation if it was a factory 4WD. It was still optional for a customer to request a Napco conversion which would have been a C ( Conventional ) designated cab. The inward mounted rear shocks were standard till 62.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 06-18-2015 at 02:56 PM. |
06-18-2015, 04:45 PM | #19 |
It's a 60 cab for sure, other is mix of 60-62 parts.
1960 Chevy Apache10 Short Fleetside 1961 Chevy Apache10 Short Fleetside 1961 Chevy Apache20 Fleetside 1963 Chevy C10 Short Fleetside 1965 Chevy C10 Short Stepside 1965 Chevy C10 Long Fleetside 1966 GMC 1000 Long Fleetside 1966 Chevy C10 Short Fleetside |
06-18-2015, 10:58 PM | #20 |
clean up the rest of the frame vin and take a pic then we can figure out what year the frame is
06-19-2015, 12:03 AM | #21 |
06-19-2015, 12:10 AM | #22 |
Should be 5 more in front of that ... the J says it was built in the JANESVILLE plant
06-19-2015, 12:14 AM | #23 |
06-19-2015, 12:14 AM | #24 |
06-19-2015, 12:26 AM | #25 |
You might have a 1962 SWB 4x4 that had a 1960 cab swapped on for some reason. Hard to say. Not too sure I would care. Might get the frame and cab VIN straightened out at the DMV to make sure nothing is stolen, wash it up, and drive the wheels off it.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
