Roto Reuter thats the name...
![]() Join Date: Feb 2010
What radiator/transmission cooler for LS3 swap?
It looks like I'm going to use the GM Performance Connect and Cruise LS3 6.2L, 480 HP with 4L70E transmission for my build (part #CPSLS3764804L70E). I would like to use a radiator that has the transmission cooler built into it instead of running a separate cooler (if possible) for a cleaner install. I'd like to get some feedback on what others have used, and if I need to run anything special. I would think that I could have the trans cooler built into my radiator for this set up. Thanks for your feedback.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
Cruzzzn' Vet
Re: What radiator/transmission cooler for LS3 swap?
Pricey, but if your gonna do it right
![]() ![]() http://www.jegs.com/i/Be-Cool-Radiat...rentProductId= |
meowMEOWmeowMEOW
If you change your mind, I can vouch for running a trans cooler solo. Get a fan cooled unit on a separate switch. Soooo nice for heavy traffic or staging lanes.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#4 | |
Where would I mount a fan cooled unit? Would it go in front of my AC condenser? If so, how would that affect the radiator? What about using a cooler built into the radiator along with a frame mounted cooler?
meowMEOWmeowMEOW
I run a fan cooled unit vertically between my framerails just after the core support. I have a stalled 4l80e and the trans creates a solid amount of heat. I didn't want to put that extra heat load on my radiator, and I already have a passive 2 row cooler for my hydroboost cooling.
I don't like the internal ones because every pass the trans cooler makes is one pass less the radiator gets for cooling out of the same square footage, or the added thickness that some of the HD ones have. Yes you could run an additional cooler to your internal unit, but going with a fan cooled one at that point would be a waste. Just consider that your paying more for the radiator to start with (unless you get it from a donor), and then adding the additional external cooler. Compared to the cost of a good medium sized fan cooler, which is usually under $200.
![]() Join Date: Mar 2004
I will be using the Entropy radiator that is specific for the LSX. I'll be using their built in 2 row tranny cooler as well. Like yourself I didn't want a separate fan/cooler but BREW sounds like he has a sweet azz setup but my convertor/tranny is stock. Buy their fan switch and you can keep the fans on 24/7 if you feel like over-riding them with a simple switch. Mine will be here tomorrow. You can have it because mine will never be done. Lol
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 Last edited by GMC-YA68; 06-21-2015 at 11:01 PM. |
#7 | |
meowMEOWmeowMEOW
I've got way more pics in the build (link in sig), but here are a couple. DeRale makes good products, but its worth going to their upgraded units (coated fins,multirow multipass, easy to hook into with AN).
Well, you just gave me an idea and a reason to spend more money, thanks a lot
![]() I will still use the built in Radiator cooler then output to an external cooler (that was my plan) like BR3W posted. Transmissions hate heat, and I'm using a little stall in my TC too so I will at least feel better. 4L70E's that comes with the 480 HP C&C are borderline at supporting 495 lbs. TQ. Cooler the better, to a point. |
![]() Join Date: Apr 2005
I recommend running an auxillary cooler as well. Another advantage to an aux cooler (as well as the cooling) is the extra capacity it provides the system.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
I'm running a Trans cooler as well with my setup. I've got it going through both the radiator and a separate cooler.
My temp seems to stay around 150. Just curious what Temps you all are seeing. |
Thanks for the pictures BR3W. That's a nice set up. I agree that DeRale makes some nice products. I actually looked into a frame rail type or heat sink type for my last build, but changed my mind. I guess I'd like to see more pictures or ideas of what others are doing. Rob if you have any pictures let us know.
What did Chevy do on cars that ran these stock 430 HP or 480 HP LS3 / 4L70E set ups?
#14 | |
#15 |
Most Chevy vehicles incorporate the transmission cooler into the factory radiator. Many people use those in line with an external cooler, or some may choose to use a different tranny pan to add more fluid, or do both. You can always read through your C&C instructions and see what they recommend for your package. I have the same 4L70E you will be getting, but running a circle-D converter with a 3K stall and I am going to plumb through my Entropy radiator then to an external trans cooler for the added comfort it will stay cool when I need it too.
