Old 06-26-2015, 12:26 PM   #1
TypeSL2
Air Line Size Upgrade
I just finished installing my BCFab Level 1 kit on my 64 and have found the 1/4" air line lowers the truck a bit slower than I thought it would. If I wanted to go from 1/4" to 3/8", what all fittings would I need to get? I have the manual paddle valves that have 1/4" outlet. Would this be a problem, or could I just get a 1/4" to 3/8" t-fitting to convert this to the size the bags need? Would the lines coming from the tank to the valves need to also be 3/8"? Thanks in advance.
James
TypeSL2 is offline   Reply With Quote
Old 06-26-2015, 02:36 PM   #2
blown240
blown240's Avatar
Re: Air Line Size Upgrade
You probably will only need to change the hose fittings to the next size up, and leave the threaded part the same size as you have now.
Using 1/4 inch valves with 3/8 tubing will be fine, it just won't be as fast as bigger valves too. It will be faster than 1/4" tubing though.
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 07-04-2015, 01:24 PM   #3
edflores
The paddle valves themselves, not the line size is what is limiting you.
I assuming you mean the drop speed is unbearably slow?
edflores is offline   Reply With Quote
Old 07-04-2015, 06:48 PM   #4
TypeSL2
Yes. Drop speed is crazy slow. It airs up quick enough. I am gonna take the paddle valves apart and see if I can "adjust" it, and possibly move the exhaust to out if the cab
James
