Old 09-05-2003, 06:12 PM   #1
MJN
MJN's Avatar
blazer stalls
My blazer will stall after short trips or after climbing a hill (lots of throttle) I stopped at a stop sign and it died, so I wiggled the power wire to the distrbutor and it fired up again. It's an HEI and I put a wire off a '78 truck on it so the module won't burn out. It might just be a loose conection at the cap but if you guys have any idea of what it might be it would definately be appreciated, since I'm so far from home right now. thanks in advance!
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 09-05-2003, 07:13 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Are you sure is isn't a carb problem?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-05-2003, 08:48 PM   #3
Leinie
I'd check the distributor cap and rotor, fuel filter,fuel pump, timing and then start looking at the carb.
Leinie is offline   Reply With Quote
Old 09-06-2003, 12:18 AM   #4
MJN
MJN's Avatar
seems like electrical, because everytime it happens I lose all power. no lights, radio, nothing, until I wiggle that power wire and it all comes back.
Old 09-07-2003, 01:21 AM   #5
Russell
Professional Grade
Russell's Avatar
I would find out where it is loosing connection in that wire, then just replace that certain spot...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-07-2003, 10:11 AM   #6
MJN
MJN's Avatar
I'm going to look at it today. and see what I can see. I'll let you know what happens.
Old 09-08-2003, 08:10 PM   #7
MJN
MJN's Avatar
I checked everything out today, can't figure out why I lose power to everything but the carb may have a part in it stalling. I had a little trouble with it on the trip up to school and I know it's not the greatest carb either. All the wiring looked good and was plugged in good so when I get another chance, most likely this weekend, I'll looke for a short of some kind.
Old 09-09-2003, 11:53 AM   #8
bouncytruck
SKINNY TIRES RULE!
I had problems with the plug that goes into the back of the ignition switch. It was totally melted. The truck would shut off randomly. Sometime, I could start it right back up, other times, it would take 5-10 minutes. It took me forever to track down the problem. rebuilt the carb, put on a new cab, control module (HEI), plug wires and finally a whole new distributor. I was about to replace the fuel pump, too. For some reason, I decided to remove all the extra wires under the dash from previous owners stereos and discovered the failed plug. It was a cheap fix (also got a new ignition switch and new key cylindar at the same time.)
bouncytruck 1972 K5
Old 09-09-2003, 01:35 PM   #9
MJN
MJN's Avatar
I'll take alook at it can't hurt I guess. thanks
Old 09-11-2003, 11:04 PM   #10
MJN
MJN's Avatar
not the ignition switch but thanks, I had problems today again, wiggled the alt. wired and it fired up. I think it's time for a whole new harness in this thing. Just have to fine the time, seems to be more valuable than money lately.
Old 09-28-2003, 05:55 PM   #11
MJN
MJN's Avatar
I think I figured it out. The drivers side fuse holder in the front harness was broken off the wire. After I spliced another in (while in the dorm parking lot and in the rain) it fired up and the battery gauge is working now. I also fixed my heater core in the parking lot and now have heat and a defroster once again. Thanks for your suggestions guys!
