Old 06-30-2015, 08:57 AM   #1
jrpitdog
Battery/circuit gremlins
So I have a parasitic drain on my battery (optima red top). It's not a lot, it takes about a week of sitting for it to drain. I tested with a multimeter and found about 150ma draw. I pulled the fuses and discovered it was the circuit with my two autometer gauges, water temp and oil pressure, both electronic gauges. Because of conditions when this truck was built those are the only thing on the circuit. The gauges don't work without the key on so how are they drawing power? Second question, can anybody confirm Optima batteries being bought out and quality going downhill? I'm thinking Odyssey for my next battery.
jrpitdog is offline   Reply With Quote
Old 07-01-2015, 11:37 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Battery/circuit gremlins
How do you have the temp and pressure sending units wired? To a constant volt source or to a keyed source?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-01-2015, 11:53 AM   #3
jrpitdog
I'm not sure, I didn't wire the vehicle, but I was thinking that might be the issue. I'm not positive exactly how those gauges work, but if the sending units were always powered wouldn't the gauges be on all the time? When I shut the truck off the needles drop.
Old 07-01-2015, 12:22 PM   #4
blown240
blown240's Avatar
From what I understand the senders just supply a ground to the gauges. It could be that one of them is not working correctly. Are you able to unhook one or both of the gauges from the circuit to see if you can further narrow down the 150ma drain?
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 07-01-2015, 01:41 PM   #5
jrpitdog
I will try that next, thanks
