Old 06-30-2015, 05:15 PM   #1
65chevysub
65chevysub's Avatar
front disc brake line
Is there a preformedbrake line for front disc brakes for my 65 Suburban? I made one from straight brake line using my original line as a template but it isn't against the crewmember like it should be. I know that disc brake line is smaller in diameter.
65chevysub is offline   Reply With Quote
Old 07-01-2015, 06:28 PM   #2
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Re: front disc brake line
Hi 65chevysub. There should lots of choices available. I bought a set from CPP. See the pic below. It includes two lines to allow splitting the system front & rear, and connects to the original rear lines.
Keep in mind... I also have CPP's master/booster/proportioning valve combo that these lines are designed to connect with. If your prop valve isn't attached to the master cyl, these lines will not fit without mods.
Hope that helps.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 07-01-2015, 10:21 PM   #3
65chevysub
65chevysub's Avatar
My setup is from Master Power Brakes. I had to make the 2 lines going down from the m/c as well. I tried to upload pics of my lines but they won't go from my phone. I'll check online or with MPB to see what they have.
Thanks for the help
