06-30-2015, 10:18 PM | #1 |
Pics of how low trucks go with ONLY bags
Just curious to how low a 69 short bed will go with just firestone bags all 4 corners, nothing else. I want to get an idea if it's going to be low enough for my liking, or if I should have some more work done to it.
Any pictures are much appreciated. Nick |
07-01-2015, 12:14 PM | #2 |
Re: Pics of how low trucks go with ONLY bags
c notch in rear, bags all 4 corners, front 2.5 drop spindles
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
07-01-2015, 12:37 PM | #3 |
Keepin an eye out
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
07-08-2015, 11:43 AM | #4 | |
thanks jeff in long beach. |
07-09-2015, 11:52 AM | #5 |
You need the 2.5 spindles so your tires sit on the road flat and wear properly.
The outside/inside of your tires will wear a line around them fast.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
07-01-2015, 02:32 PM | #6 |
Thanks fellas. So with mine not having a c notch or drop spindles or block, should I expect mine to sit slightly higher, or does that just have to do with ride height?
07-01-2015, 04:12 PM | #7 |
When I went to bag my truck, I ran into the same issue. There were only pictures of serious, drop member or z'd frame trucks. So when I bagged my C10, I did it in stages. First I did just the bags, then I added drop spindles and then a notch. I took pictures of my truck in the same location, at the same angles each time so that it would be easy to compare. When I was done, I made the chart below. Here's the link I started when I was done:
http://67-72chevytrucks.com/vboard/s...d.php?t=609897
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
07-01-2015, 05:29 PM | #8 |
that's awesome, that's exactly what I was looking for. Thank you!
Nick |
