Old 07-01-2015, 09:19 PM   #1
gmachinz
Introducing-Junkyard Tech episode 1!!!!
Ok...so if a lot of you are like me, you enjoy perusing your local junkyard looking for later model upgrades for your square, right?
Well, here's a little project I did in literally one hour just to see how it would turn out....the mission?
Adding a stout electric fan to an otherwise stock fan shroud assembly to negate the need for fabbing up some custom mounting brackets for the fan assembly itself.
So, here's your checklist of what you need:
1.) A Tbird or Mark 8 electric fan assembly
2.) Stock truck shroud (I used a BB one but a SB one should work as well)
3.) Drill with a 1/4" drill bit
4.) Rivet gun
5.) 1/4" rivets, 3/4" length and washers
6.) PVC saw
7.) Dremel w/cutoff wheel
gmachinz is offline   Reply With Quote
Old 07-01-2015, 09:21 PM   #2
gmachinz
Re: Introducing-Junkyard Tech episode 1!!!!
Cutoff the fan assembly mounting ears using your PVC saw.....
Old 07-01-2015, 09:23 PM   #3
gmachinz
Next, lay the Motorcraft fan inside the truck shroud, center it and mark the fans' reinforcement ribs to trim down....allowing it to sit more flush inside your truck shroud like so....
Old 07-01-2015, 09:26 PM   #4
gmachinz
Now, with the Motorcraft fan centered, drill a hole through both the truck shroud and the Motorcraft shroud-make sure to check your holes so that they align in a way that allows each hole to cleanly go through both-I marked my holes to drill with a silver paint marker....
Old 07-01-2015, 09:33 PM   #5
gmachinz
Lastly, simply drill and secure one hole at a time-using a washer on the backside to make sure you get a good, tight compression of the rivet head. Once you're all done, the whole assembly will bolt back up and look stock-how you trigger the fan can vary depending on your preference....I'll end up securing one of my fan control relay bank directly to the truck shroud a easy-peasy and stealthy to boot! You could also trim off a couple sides of the Motorcraft fan inside the truck shroud for added "shrouded" air to come through-I'd even take it a step further and use some high heat insulating foam between the truck shroud and radiator also.
This is a pretty good fan upgrade if going electric and is a great way to clean up the engine bay on serpentine converted trucks!
Old 07-01-2015, 10:13 PM   #6
mattcrp1
mattcrp1's Avatar
looks good, simple and clean.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 07-01-2015, 10:25 PM   #7
greg64
greg64's Avatar
Great junkyard tech! Thanks.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 07-02-2015, 12:15 AM   #8
gmachinz
For those who may not know, the Motorcraft fan opening on the shroud itself is a hair over 18" in width, so as long as your shroud opening is 19" or larger it will work. Also, the depth of my junkyard tech cooling fan assembly is 6" from truck shroud face to back of fan motor-so be sure to check your water pump-radiator fin distance....you need at least 6.25" or more.
Old 07-02-2015, 08:38 AM   #9
bnoon
Very nice! I have an extra nice shape BB shroud I'll sell you cheap if you want to offer a loaded one for selling on here.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 07-02-2015, 09:17 AM   #10
Rich84
Rich84's Avatar
This would be a nice setup for the LS swappers too..Those fans work so well that you don't have to go crazy sealing them up.
Rich84 is offline   Reply With Quote
Old 07-02-2015, 10:43 AM   #11
cooperhw
cooperhw's Avatar
Very nice. I will be saving this for the future. Thanks for taking the time.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 07-02-2015, 11:28 AM   #12
gmachinz
No problem-I actually used a 73-80 BB shroud-of which there appears to be at least 3 variations. I don't see why a SB shroud wouldn't work just as well. If I do anything else I'll most likely dremel off both sides of the Motorcraft fan at least so that the truck shroud is funneling all the air.
Bnoon, I have several shrouds still too-I suppose I could build them and offer them for sale but I figured a lot of guys might like an excuse to go junkyarding-lol. I'm all out of Volvo dual speed fan relay kits at the moment so I'll just put a dual speed relay kit on it and see how it does. I still want to stop by and check out your truck again!
Old 07-02-2015, 02:25 PM   #13
bnoon
I used the same SBC stock clutch fan with the BBC and SBC radiator setup. The SBC fan shroud is deeper than the BBC one by a few inches, so the BBC one gives you the most room.
Come on by!
Old 07-02-2015, 11:33 AM   #14
Corts60
Just here to tinker
Corts60's Avatar
Very well done! Thanks for posting.
Old 07-02-2015, 04:12 PM   #15
geezer#99
geezer#99's Avatar
While you did do a nice job, I gotta ask why you'd want to put a fan that has a shroud already into a shroud on your rad.
Defeats the cooling process!
Hiding it maybe!!
Old 07-02-2015, 05:22 PM   #16
gmachinz
Hiding it maybe!!
No...it won't defeat the cooling process-trimming the fan sides will allow it to be fully functional. I tried it this way because there's no clean way to mount an electric fan without it looking out of place sometimes. And, I detest v-belts and prefer serpentine drive anyway.
Old 07-02-2015, 04:54 PM   #17
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Have you tested it yet? Curious how this will perform.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 07-02-2015, 05:24 PM   #18
gmachinz
Gary
I will be as soon as I get my radiator in-I am modifying a core support brace a little so I can run a late model AC condenser for way more volume.
Old 07-02-2015, 08:02 PM   #19
GASoline71
GASoline71's Avatar
Hope it works!
Gary
