Which wheel center?
I have two options I am torn between. I am going to be running 15X8 steelies on my 4X4. Do I run the 85 centers I was thinking of, or do I run the centers off an 02 silverado? I feel the 85 although closer to an original style are not original, and will scratch up my freshly powder coated wheels. Whereas the 02 centers bolt to the lug nuts so no scratchy. Yes I can machine the centers of the 02 to fit over the 4wd hubs and I have the front 4wd set from the 85. Not much about my truck is going to be original. Anyone willing to share opinions?
Re: Which wheel center?
I think both look pretty good. Could you put tape on the inside of the '85 centers to avoid them scratching the wheels? Maybe run one style on one side and the other on the other side, for a little while, and see which one grows on you.
I like the smaller 02 caps.
![]() ![]() Join Date: Jul 2002
I like the looks of the 02 caps a little better, but both would be good. Heck, switch them back and forth as you get tired of one.
![]() Join Date: May 2010
Another vote of the 02' centers.
It only has original paint once |
02s
Another vote for the '02 centers
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
You could strip and polish the 73-87 caps.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
I like the 85 centers, 02 doesn't look quite right with the hubcap nubs on the rims. Of course I've always been kind of partial to those square body hub caps anyway. Joseph
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed ![]() ![]() 1966 C-10 lwb,factory A/C,Custom Cab ![]() 1954 Delray 2-door sedan [rat rod project]
I did something similar, adding the newer centre caps. I'm not sure what size lugnuts that the 4x4's run... but if they're 7/16 you should make sure that the taper on the nuts fit into the conical seats in the wheels. I had to turn mine down to fit.
See posts 77 & 78 of my build thread below.
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram ![]() |
Thanks for all your inputs, I think I am going to start with the 02's primarily because once I snap on the dog dishes there is no going back. Johnny_Lamebridge thanks for the heads up on the lug nuts that is something I had not considered, I can however machine those to.
I run my original caps on the same rims. Mine are painted and I have had very little damage to the paint. What couple of scratches I get are covered with the caps installed.....just throwing that out there. With the powder coating being a tougher finish....you may not find as much damage to the finish as you think.
Hey dodgiesdad,
I don't believe there was ever any factory 7/16-20 lug nuts with the external thread to accept to accept the "truck size" plastic nuts, so you'll have to find aftermarket nuts. I bought mine on ebay from a seller named lugnutking or something like that. He even sent me an extra nut, 25 instead of 24. Look for external thread or dual thread lug nuts, 22MM.
Who Me?
Id go with the 85 centers.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
