07-05-2015, 06:21 PM | #1 |
Dual Use Fuel Pump
With budgets being tight this year I had decided against the twin turbo LSx motor what with all the extra plumbing and so forth and decided and nice mellow 600 something hp BBC.
Do you guys have any experience running some of those dual use electric fuel pumps? The kind that can be used for either a carb or FI? I was thinking about going that route so that in the future I could install the FAST 2.0 System without having to swap out pumps and re-plumb it for FI.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
07-05-2015, 08:41 PM | #2 |
Re: Dual Use Fuel Pump
I run a Aeromotive A1000 pump and return regulator, it will support high HP injected or carbed motors.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
07-05-2015, 09:27 PM | #3 |
mini truck racer
I also run an Aeromotive with a return regulator . The regulator came with a high and low pressure set of springs .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
07-06-2015, 03:05 AM | #4 |
meowMEOWmeowMEOW
If you have a good reg like the others mentioned, you can put as much pressure into it as the pump supplies, since the reg will take it down to the desired level for you. Just make sure you don't have one of the low-pressure only regulators, otherwise your good. (and make sure any filters before the regulator are rated for the full pressure!)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
07-06-2015, 03:46 AM | #5 |
Thanks Guys!
