09-06-2003, 08:08 AM | #1 |
Lights
I have just installed the painless wiring harness and have the following problems: Parking lights come on ok as well as blinkers until I turn on the headlights. Then the parking lights don't work. Also the dash lights don't come on at all. I verified the bulbs in the dash as well as the foil runs. I have a new headlight switch installed. Thanks Kerry (Wootdog)
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
09-06-2003, 08:21 AM | #2 |
Car Knocker
Man, all I can think of is ground wires. I fixed my dash lights once every thing worked until you put a turn signal on. Then whole dash would blink. had bad ground wire. Did you run a new ground to the radiator support? Head lights maybe taking the ground from parking lights. With new light switch though I maybe way off but just running an extra wire will be easy enough to check out.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
09-06-2003, 08:51 AM | #3 |
I agree, it definitely sounds like a bad ground. Good Luck
09-06-2003, 12:56 PM | #4 |
THIS MIGHT BE KINDA DUMB BUT, IS IT A GMC? MY PARKING LIGHTS GO OFF WHEN I SWITCH THE HEADLIGHTS ON. THAT'S THE WAY THEY'RE SUPPOSED TO WORK IN MINE. ALSO YOU SAY THE PARKING LIGHTS WORK OK...I HAD A SIMILAR PROBLEM WITH ONE OF MINE...WHEN THE PARKING LIGHT WOULD FLASH IT WOULD GO VERY DIM COMPARED TO WHEN IT WAS JUST ON..FIGURED OUT THE TWO WIRES THAT GO TO THE PARKING LIGHT WERE REVERSED..DUAL FILIMENT. ONE FOR FLASH(BRIGHTER) THE OTHER FOR RUNNING LIGHT(DIMMER). ONE WIRE IS BLUE THE OTHER PURPLE. AS FOR THE DASH, YOUR GROUND WIRE IS IN THE PRINTED CIRCUIT AND COMES OUT THROUGH THE FACTORY PLUG..I TOOK THAT WIRE AND RAN IT STRAIGHT TO THE DASH TO GROUND IT AND I HAVEN'T HAD A PROBLEM WITH DASH LIGHTING SINCE...
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
09-06-2003, 02:21 PM | #5 |
I believe your '68 is like mine. When I turn my lights on the park lights go off also and they are supposed to. just as long as the turn signals still work with the lights on. As for the dash lights I think the others are right on with the ground wire suggestion.
Good luck
'67 C10 LWB FLEETSIDE, WEAK 305 , TH400, 3.73 REAR COLORADO SPRINGS, CO. |
09-06-2003, 03:13 PM | #6 |
Young Gun wth Fast Inline
the 67/68 switches are different, the parking lights go off when u turn on the headlights. You can get a newer switch to correct that/.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
09-06-2003, 08:06 PM | #7 |
It's just a check engine lamp.
I hope I'm not hijacking the thread.
stelth2002--I was very curious about your 292 and the work you've done to it. If you get a chance could you email me at bigchevy66@hotmail.com If you get a chance you might want to visit www.inliners.org
Active Inliner---bigchevy66 68 SWB Stepside 250 L6/3 on the floor/ Hedman headers, HEI, MSD 6A box, K&N filter, Offy intake and Edelbrock 600cfm 4 barrel Soon to have: WC T-5 five speed 66 SWB Stepside-undergoing restoration |
09-06-2003, 10:53 PM | #8 |
its all about the +6 inches
I always thought it was just the 67 that the parking lights went out.
Do your tail lights stay lit? |
09-07-2003, 09:44 AM | #9 |
lights
Yes the tail lights stay lit. The dash lights still don't come on. I will try the ground thing today. This is a 67. My 68 parking lights stay on with the head lights on.
