Old 07-08-2015, 10:17 AM   #1
fatblockvelle
fatblockvelle's Avatar
1971 K5 , Broke Front Axles Help, interchange.
both fronts are broke at the u-joints.... Have heard from a few people you can use newer ones? same spline??? upgrade??? there an interchange chart?
Any help would be appreciated ! Thanks.
1970 chevelle
1971 blazer
1972 c20 custom camper
1931 ford A coupe.
fatblockvelle is offline   Reply With Quote
Old 07-08-2015, 10:24 AM   #2
turp mcspray
turp mcspray's Avatar
Re: 1971 K5 , Broke Front Axles Help, interchange.
73 up will swap right in. I have always used them in mine. They use a bigger joint and are a beefier axle.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 07-08-2015, 10:30 AM   #3
fatblockvelle
nice!!! so if i have3 some out of a 79 k10 they will swap in?
1970 chevelle
1971 blazer
1931 ford A coupe.
Old 07-08-2015, 12:18 PM   #4
fp1967
fp1967's Avatar
79's would be from a 10 bolt axle and the inner axles won't fit a Dana 44. The outer stub axle will fit though. From what I have seen, they started using the bigger axle joints in mid 72. In mid 77, they started using 10 bolt axles.
fp1967 is offline   Reply With Quote
Old 07-08-2015, 12:21 PM   #5
fatblockvelle
YES... I JUST NEED OUTERS.... SO I SHOULD BE GOOD!!!! Thanks!!!
1970 chevelle
1971 blazer
1931 ford A coupe.
Old 07-08-2015, 03:18 PM   #6
kwmech
Maybe not, check the u-joint size. The early 44s had a 260 u-joint that had 1-1/16 caps and the later models were 1-3/16 which is a spicer 5-760x.
From late 72 (2nd design) up through 1991 in the blazer and suburbans took the larger joint, 44 and 10 bolt
Old 07-08-2015, 03:22 PM   #7
fatblockvelle
yes but worst case i can get adapter joint... i just have the 79 outers already.
1970 chevelle
1971 blazer
1931 ford A coupe.
Old 07-08-2015, 05:55 PM   #8
kwmech
No such thing for an axle shaft
Old 07-08-2015, 03:37 PM   #9
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I have a set of OE 72 axles inner and stub. excellent condition... LMK
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 07-09-2015, 01:05 PM   #10
D.PASSMORE
One of the First
D.PASSMORE's Avatar
This might help:
http://67-72chevytrucks.com/vboard/s...d.php?t=670179
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
