07-09-2015, 11:17 AM | #1 |
'63 cab to '84 frame swap???
Alright so I'm gettin ready to drag my 63 bbw out of its wooded grave. I already have a 84 C-10 in the back yard that semi runs. And I have the cab and front sheet metal sold already. So. Has anyone ever put a 60's cab on a frame that model? On a 1-10 scale how hard is it and what am I looking at??
Thanks!
WWW.TASKFORCEERA.COM '47-'59 Chevrolet Truck Clothing |
07-09-2015, 12:35 PM | #2 |
Re: '63 cab to '84 frame swap???
It would be much easier to swap the suspension and drive train from the 84 to the 63 than to do the frame swap. There are lots of examples on here of how to do it. Swapping the front crossmember takes about 14 bolts, drill a couple of holes and an adapter plate for the steering box. The rear axle will need new mounting pads.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
07-09-2015, 02:20 PM | #3 | |
07-09-2015, 02:54 PM | #4 |
I swear this topic gets asked every other day and has been covered a thousand times. Can it be done, Yes. Is it more work than just swapping the front crossmember, you bet! Does swapping the 84 frame make a c10 look like a stock k10 height wise, yep! Pulling the motor/trans out of the 84 with no sheetmetal should only take 15min.
- Patrick 1964 GMC pickup lwb ~ My newest build! 1937 Ford Coupe ~ Custom frame, LS1, quickchange 1950 Chevrolet 3100 ~ Bagged (Sold) 1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car) 1967 Chevelle ~ 454 Triple Black (Sold) 1964 Chevrolet Impala SS (Sold) |
07-10-2015, 12:49 AM | #5 |
60-66 Nut
Yes this question does get asked a lot. A simple search will show many results. I am too tired to type my response I have typed probably a hundred times, so I will just leave this link.
http://www.67-72chevytrucks.com/vboa...d.php?t=481023
