Old 07-11-2015, 09:51 PM   #1
king-918
king-918's Avatar
Doing a 5.3 4lx0le swap, please help
What parts of the harness do I need to keep and what parts can I throw away as far as just pulling it out of the vehicle
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 07-12-2015, 09:27 AM   #2
Wgesnerjr
Wgesnerjr's Avatar
Re: Doing a 5.3 4lx0le swap, please help
I bought my engine and trans from a yard and they left the center plug and cut the others as far as the could. If you are going to use the under hood fusebox, you will need the other plugs. If not, they may be useful but might not be needed.
Check this site for details
http://www.lt1swap.com/wiringharness.htm
I have been following these instructions and they have been very helpful.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 07-13-2015, 09:03 AM   #3
MalibuSSwagon
I have my 5.3l running with the under hood box. Takes a lot of the guess work and hack out of the swap.
MalibuSSwagon is offline   Reply With Quote
Old 07-13-2015, 09:42 AM   #4
king-918
king-918's Avatar
Thanks for the reply, do you guys have pictures? And what engine mounts did you use?
<----Christopher
Oklahoma
Old 07-13-2015, 11:24 PM   #5
Wgesnerjr
Wgesnerjr's Avatar
I used some engine brackets I got off eBay from kids-performance. They were just under $100 and they fit great. For the mounts I used the cheapest stock replacement mount I could get from autozone.
On vacation right now so I can't take pics. Will try and remember to take some when I get home.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 07-14-2015, 09:02 AM   #6
SCOTI
SCOTI's Avatar
Dirty Dingo for the mounts....
http://www.dirtydingo.com/shop/index.php?cPath=359
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-17-2015, 04:21 AM   #7
andrewmp6
I believe you can use the stock cluster out of a 90-91 suburban k5 and crew cab.The ac i believe you can have a shop custom make your ac lines and wire up the ac clutch should be good to go.
