Old 07-14-2015, 08:56 AM   #1
Gmcbroken
How to go about this
I have a 5.3 4l60e out of a 04-05 yukon xl. Is has a computer controlled regulate.how do I bypass this. My harness will get reworked to the basics. I just Wana run a inline pump.any help would be greatly appreciated.
Gmcbroken is offline   Reply With Quote
Old 07-14-2015, 09:25 AM   #2
ls1nova71
ls1nova71's Avatar
Re: How to go about this
Thats most likley a flex fuel sensor. You can just eliminate it, but just dont try running e85 in it when you're done.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-14-2015, 09:45 AM   #3
Gmcbroken
I know it's gonna sound stupid but eliminate mears wire and all wherever it hooks up at. Will the computer get a error code I should be worried about. Can I have this eliminated in the harness rework.thanks again guys
Old 07-14-2015, 11:26 AM   #4
Gmcbroken
Old 07-14-2015, 11:27 AM   #5
Gmcbroken
It is a flex fuel sensor that's all I know
Old 07-14-2015, 12:16 PM   #6
indymachinist
that is a flex fuel sensor and a fuel filter. there is no regulator there. pretty sure on the truck systems the regulator is right up on the rail on the intake manifold.
you dont need that if you dont want it. just leave it out and tell whoever is tuning your computer to turn it off.
indymachinist is offline   Reply With Quote
Old 07-14-2015, 01:02 PM   #7
bpatrol
walbro 255 fuel pump and go
bpatrol is offline   Reply With Quote
Old 07-15-2015, 07:39 AM   #8
aknovaman
Hope you have a competent tuner that knows to zero out the flex fuel modifier tables as well as the codes for it. Also the injector tables are different than a non flex vehicle. He needs to use a flex file and just kill the codes as well as zero the tables. Use a non flex file and your fuel trims and other settings wil mess with drive ability along other things.
The easiest thing would be to just leave the sensor in there as all fuel has some alcohol in it and let the sensor do what it's designed to do.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 07-17-2015, 12:36 AM   #9
boostedc10
boostedc10's Avatar
04 and up is returnless and regulator is in the tank. Aknova is right, if you don't have a good tuner or know what your are doing, just leave it in the system. It won't hurt anything and save you a headache on the tune side.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
