07-14-2015, 11:08 PM | #1 |
3speed column shift help!!! 1959
Please help if you can. I want to see if it is an adjustment problem before I resort to pulling the tranny. I rear ended some one and had no visual damage to the truck but my ability to shift into 1,2,3 is intermittent. My linkage seems to bind upon visual inspection but I don't know if it is binding inside the tranny. After failing to shift into 1 I was able to get it back in once and went all the way to third with no problems. After stopping and trying to shift to 1 it would not go into gear. ...any thoughts would be greatly appreciated. I don't want to pull the tranny unless I have to.
Posted via Mobile Device |
07-14-2015, 11:13 PM | #2 |
Here is a pic
07-14-2015, 11:51 PM | #3 |
Re: 3speed column shift help!!! 1959
Usually this is a sign of slop in the column or linkage. My 69 does it as,well. It won't do it if I go 3,2,1 skip 2 and it binds.
07-15-2015, 01:21 AM | #4 |
07-15-2015, 01:23 AM | #5 |
Thank you mike69! What is the best way to remedy slop in the linkage?
07-20-2015, 11:10 AM | #6 |
Have you replaced all the plastic bushings?
they might have cracked and fallen out
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
