At temps over 65, when I'm sitting idling for a few minutes my temp climbs to almost 230, once I start moving again it goes right back down. I've checked my fan clutch, when I give it a good spin by hand, it doesn't go more than 1/4 turn more when the engine is outside temp (cold). I changed the thermostat last fall, and put in a 195, because it was doing this same stuff then. but over the winter didn't have any problems because it was cold outside. It has the original factory radiator in it, I'v looked down in the fill cap, it looks clean on that end, but could it be plugged up on the other end where the water returns from the engine? Or am I looking at a impeller on the water pump that is slipping? I'm fresh out of idea's guys.
Re: Engine gets hot at idle
Do You have a fan shroud??
Do you have a fan shroud?
Is your fan half in/half out of the shroud? Any obstructions in front of the rad? Have you put a piece of paper in front of the rad to watch for air flow thru the rad? Does your top rad hose pressure up? |
#4 | |
How's your coolant? Half & Half? Fairly new? Flushed the system any? Bled out any trapped air? Have you used a pyrometer to check that it's actually overheating? Sending units can do weird things.
Current Projects: 1984 GMC, LWB Fleetside, 305/350 - Currently Doing TBI Conversion 1966 GMC, SWB Stepside, 350/200-4R - Currently waiting patiently. |
And a few more!!
Check the bottom hose. Could be collapsing. Do you have a properly functioning coolant overflow system? What's your rad cap rated at? Is it new or old? Do you have the heater core hooked up or bypassed? What's your initial timing? Retarded timing makes heat at idle! |
#6 | |||
How many blades does your fan have? How many rows does your radiator have?
My fan has 7 and my radiator has 3 rows. My vacuum advance is on manifold vacuum and initial idle timing is set for around 10-12 BTC. No overheat at idle even when running AC on a hot day. Getting a sending unit to match OEM temp gauges can be an exercise in frustration since different years require different sending units and a PO may have swapped either or both. The typical chain parts store sending unit generally won't work with the OEM gauge. Probably why you have the under dash units. |
Your fan is too far into the shroud. You might be better off to replace the fan you have with a fixed blade one that fits in the shroud correctly.
Timing was changed like that because of sight lines past the a/c pump brackets and p/s pump brackets. You couldn't see the timing tab. Easier to move it to 12 oclock. A brilliant design by a 4 foot tall engineer who had no trouble setting the timing cause he stood inside the engine bay beside the rad. LOL!! You're shooting yourself in the foot when you check your rad with a h2o hose. You just add more crap between the fins which hinders air flow. TRy the paper test. Or pull the rad and have it hot tanked to clean the fins perfectly. |
#9 | ||
Yeah that poor little midget engineer. LOL I wasn't running the engine when I blew the Rad out with the hose, and I blew it out from under the hood backwards toward the grill. Not from the fromt driving the stuff into the coils. But I'll give the paper trick a try. |
A one row rad can cool better than a four core if it's designed right! Look again. The chances yours is a one core are slim to none!!
BTW you can't say That about the engineer. He's horizontally challenged!! Any water in any direction thru your rad running or not helps plug it up. |
So is your fan clutch for a Diesel or gas engine since a Diesel came out of it? I ran a Diesel clutch and was having weird temperature issues. They are different part numbers and lock or unlock at different RPMs and temperatures.
Another thing to check is ,does your truck have a heat riser (spring or vac operated flap) between the r side exhaust manifold and the exhaust pipe. I had one with the same symptoms as you described ,driving temp would be ok ,idle at traffic light mine would go above 230 if I let it idle long enough it would boil over. The flap was seized in the closed position, Bob
#13 | |
#14 | ||||
Nonstop, You know that could be it, lord knows what this PO did under the hood, but it seems to be grabbing just fine, I went for a ride earlier today and checked to see ho it would spin while it was at full temp. It stops moving as soon as my hand quits moving it. The PO left a rats nest of wires under the hood from the Diesel engine so I've had fun grouping all the extra stuff together, and bundling it all off to one side. Burkeftm, I wish it was that simple, but I went to headers last fall, before it got cold, so that thermal flapper isn't even hooked up. Good thought though. Blessed66, since mine started out as a Diesel it never had that converter on it, thank god. But a good idea though. |
#15 |
Are you using the right fan and clutch for the application (clockwise or counter clockwise)? What are the basics - timing, functional vacuum advance? Radiator may simply be too small.
#16 |
If you have a single core radiator, then that's where I'd start. I don't think I've ever even seen one in all the squares I've had and parted out, and I dang sure wouldn't run one in a driver.
#17 |
I don't think any of my trucks ever had a fan clutch. I figured the General didn't put them on trucks. (?) Your problem sounds like the issue I have been having with my motorcycle for many years (I know, completely different). It cools fine as long as air is moving through the radiator but in slow city driving it will overheat in a minute. I finally ruled out everything but the radiator. I think that is the trait of clogged radiator; overheating quickly as soon as the air flow slows down. I would bet my money on a bad radiator. Good luck.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#18 |
When you mentioned the PO swapping from a diesel, I wonder if the PO had budget issues. That radiator could have been the "cheapest thing available" so the PO could get a truck that moved under its own power. Your initial thought on the water pump impeller is worth checking. If the current engine was a salvage yard pull, no telling what shape the pump is in.
My truck came with a factory fan clutch. A lot of trucks lost them in the 70's and 80's due to flex blade fans being sold as a way to gain HP and improve gas mileage. |
#19 |
For what it's worth, I've never seen a stock GM truck without a fan clutch.
#20 | ||
Kaysen, Thanks, yeah it is too small. |
#21 | |||
Dead Parrot, It came out with a thicker Rad from what I'm finding out, I think the PO might have damaged the one that came in it, when he was switching out the Diesel, or when the Diesel blew out it damaged it, either way he went cheap on replacing it, just like he did switching from a diesel to gas. Blessed 66 your right, from 72 on they came out standard with a fan clutch, only way it came without was if you asked for it and the individual dealers swapped it out before you got it. |
#22 |
The fan can turn in the right direction and still be pitched the wrong direction. They can be installed backwards. If it blows the water you spray out through the grille that could be your problem.
#23 |
Oh no when I was spraying water through it, I was doing it from under the hood, without the engine running, and yeah I checked to make sure the blades were pitched in the right direction. Honestly I think I figured it out earlier when I went to the GM heritage center, and downloaded the build information on my truck. PO changed the Radiator when he changed motors.
#24 |
Is the water pump actually pumping coolant? Do you see evidence of a water leak (rusty water trail) at the weep hole on the bottom of the water pump?
If you need a fan clutch, I would stick with AC/Delco factory part. I have not had good luck with flex fans. From the symptoms you describe, it sounds more like a bad fan clutch to me. When the engine is overheating and you pop the hood to check the engine, do you see the fan moving? If ll else fails, a rare but possible coolant passage obstruction in the engine block could be the cause. A power flush might help that. You would have a shop with a power flush machine do that, along with a cleaning agent. |
#25 | |
I've found the fan clutch is grabbing like it should, and the blades are pitched in the right direction. It's never overheated fully, but yes the fan is moving. I can shut the truck off and go into a station to pay for gas, and after i'm done, start the truck up, and you can hear the fan roar for a few seconds moving air, then it slowly levels out. I back flushed the system last fall, when I had it all open replacing hoses, and the thermostat (now it wasn't opening when I replaced it, but works now), only thing I didn't get flushed was the radiator. As I said on a previous post, I think the previous owner replaced the Rad. with a single core when he swapped the Diesel out and put in the 350. Maybe he damaged the original during the swap. I found this out when I went to the GM Heritage web site, and downloaded my trucks build information. It's suppose to have the HD radiator, and clutch fan in it. Thats a great site by the way. |
Tags |
engine, hot idle, temp high |
