09-07-2003, 11:23 AM | #1 |
Shortbox wanna-be.
Bagged/lowered S/B trucks. What drive shaft did you use?
Anyone have pics of their lowered short beds drive shaft area?
I am building up a short box right now, but it didn't come with a drive shaft, so I am trying to figure out what I might need to get it rolling. I already have the 402, T-400, & 12 bolt rear. Pics of this area would be great. Reid
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) |
09-07-2003, 12:46 PM | #2 |
In the rear, my beater 68 has firestone 2600# bags mounted in the factory coil location + 1.5" lowering blocks, a welded 'bolt-in' c-section, and an adjustable panhard bar all from CCP.
I've used the factory 1pc shaft originally equipped w/the truck for over 3yrs now w/o any problems (sorry, I don't have any pics). To give you a visual, the top of my rear end housing rides about 1" inside the c-section @ normal ride height (w/30psi of air). The bed floor (what remains of it) above the pumpkin is my bumpstop. The biggest issue that I was concerned about: there is VERY little clearance between the factory hoop in the trailing arm c.member & the shaft . . ..... but it's only hit once in the yrs since being completed. If it hit repeatedly, you could eventually break the shaft in half under stress. Since my 67 is lower, I did have to 'hog' the c.member hoop out w/a grinder for more clearance & then boxed everything for strength.
09-07-2003, 12:59 PM | #3 |
14.1 @ 96MPH
I didn't think any of these came with one-piece shafts stock?
Regardless, mine has a one-piece now (used to have two), let me see about the photos... Five enough for you?
Project1970 - LS1 Swap Complete! Last edited by Project1970; 09-07-2003 at 01:02 PM. |
09-07-2003, 01:56 PM | #4 | |
Shortbox wanna-be.
Well, you are going to have to get some pics! I want to see how low it is. Maybe you have pics of other trucks that sit similar to yours? Reid |
09-07-2003, 02:05 PM | #5 |
Watch out for your cornhole !
6 cyliner 3 speed shortbed trucks came with 1 piece driveshafts. I have three of them currently (the trucks).
I can go outside and get pics of the underside if anybody really cares to see it.
09-07-2003, 07:20 PM | #6 |
Progress = 0%
My '67 GMC long bed with a 305V6 came from the factory with a 1-piece driveshaft (It's now a short bed). I just had it cut down the length I needed. As SCOTI said, it comes real close to hitting the drive shaft loop. I have the same bolt-in c-notch that he has (from CPP). I removed the rubber bumpers that came with the kit, so when my rear bags are empty, the axle tubes rest on the c-notch. If I were to go any lower than that in the rear, I'd have to modify the drive shaft loop for clearance.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
