![]() ![]() Join Date: Feb 2009
I'm looking for these OEM parts for a 71 Chevy
71 Chevy 1/2 ton, short/fleet, 2wd
OEM and straight metal only...rust not a concern. 1. 12-bolt differential cover. FOUND 2. 402 Valve covers using the push-on rubber oil cap. FOUND 3. Paint separator moldings (wraps around the cab under rear window). FOUND 4. Original coolant overflow tank and bracket. I believe these sat on the LH side of the radiator. Reference to a stock reproduction is appreciated. MISSING IN ACTION Note: If anyone can educate why/if there are two different "original" brackets It would be appreciated. I've seen two "originals". When mounted, one bracket is square with the bottle. For the other, the bracket slopes downward against the bottle. I'm mostly certain the one that slopes down is original. I believe both types use the same bottle. I've never seen the mounting plate for the bracket that slopes downward, so can't say they're the same.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-21-2015 at 10:14 PM. |
Re: I'm looking for these OEM parts for a 71 Chevy
Cash, trade?..................BUMP!
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Oct 2012
This guy's got a diff cover, not sure if you've seen it.
http://67-72chevytrucks.com/vboard/s...d.php?t=676357 |
#4 | |
Turns out I still need all these parts.
![]() Join Date: Jan 2010
What condition does the overflow tank need to be? I have one I believe ( just have to make sure I still have it) in used condition. It has the bottle and mounting bracket but is missing the cap. If interested I can dig it up and get photos this week sometime. Rod.
#7 | |
Incidentally, I'm still not 100% sure if the originals sit on the RH fender or mount to the LH side of the radiator. I believe it's the RH side of the radiator. I've looked this up, there appears to be some confusion.
here it is. bracket is solid and could just use a blasting and repaint. bottle is just a bit yellowed but holds fluid and is not cracked. 4th pic shows what the original cap looks like but I do not have one with it. the green cap on the bottle is not original but works. the last pic shows where it was mounted when I removed it from the truck it was on. if you want it I would do $75.00 shipped. Keep in mind it will cost me $30-$35 to ship this properly from Canada. would come thru Canada Post.
That MAY not be what the correct part Chewy. Below is a link to an interesting thread. See posts 5, 10, 14, 20 and 21. Apparently these were dealer, not factory installed. So there's some doubt of consistency. I can't say for certain they all used the same part. At least one recovery tank was a GM part. I've seen one on a SPID. Dealer makes the SPID? Heck, I don't know.
Any chance your SPID shows an overflow tank? I may still be interested. Can I trouble you for the widths of? 1. mounting strap width. In other words, the width of the vertical portion of the bracket. It's probably around 2-3". Also 2. the horizontal width of the entire bracket. I'd like to confirm this fits with the radiator and core before I ponder this further. http://67-72chevytrucks.com/vboard/s...d.php?t=546610
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-22-2015 at 04:55 PM. |
does this help. I have no idea I am confused now. truck did not have a glove box lid when I got it and that was quite some time ago now. nothing with these trucks was documented clear it seems lol.
the width of the banding holding the bottle is 1" wide
Yes, some things can be really confusing. I found that out recently in pursuit of a decent rear brake hose. Unless you know it's from an educated source, you cannot take any info. for granted. That and a loss in translation.........That's the "beauty" of the internet.
See that 3rd picture you offered above? Do a 180 with the tape measure for the width. I'm guessing it's around 2.5". I suspect yours is the GM part they referred to per that link, post 14 and 21. You might plug these numbers into Ebay, these may be what you've got: EDITED: Bracket: 15996772 Bottle: 15687277
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-22-2015 at 05:56 PM. |
on bottle 15687277 the fill neck is centered and on mine it is not and mine is much smaller. couldn't find a photo of the bracket.
oh I got it now. it is 2" wide
#15 |
Thanks a bunch Chewy.
Definately a different bottle. You couldn't locate the bracket because I gave the wrong part (sorry). Here it is 15996772: http://www.ebay.com/itm/GM-15996772-...7f83fd&vxp=mtr Damn my eyes............(too late) Edit: Your bracket would mount to my vertical core support brace, above the horn. However, if centered on the width of said brace, it would hug the radiator. In other words, may not be quite right for this application.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-22-2015 at 06:17 PM. |
#16 |
I have to disagree with post 21 in that thread as far as similarities between first owners set up and 994230. I happen to have both right here in front of me and they are identical right to the screws that mounted them. there may possibly be different part #'s for the factory and dealer mounted parts but what first owner has there is a dealer truck unit.
#17 | |
#18 |
Ha, check that out.......... Is it just me or do some of these brackets seem to hang differently? The bracket on yours above (post 8) and post 14 in other thread appear to be square with the bottle (i.e., bracket is level), while the brackets in post 10 and 20 per the other thread are at an angle (i.e., bracket slopes downward).
#19 | |
![]() Join Date: Sep 2013
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike |
#20 |
I'm interested in that differential cover. PM sent. Thanks
#21 |
Eat, Sleep, Drive a Chevy
I have the Paint separator moldings. I had them professionally straightened and polished they are ready to go! If you are interested I will take 60.00 plus shipping.
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
#22 | |
Edit: Your mailbox is full. I wrote: Are those are OEM and straight? If so, I'll take them. If you take Paypal, I'm happy to pay the difference. They charge about 4 percent. Let me know how you want to communicate this. Unfortunately, as stated, your private in-box is full. Thanks!
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-26-2015 at 12:06 AM. |
#23 | |
#24 |
Here ya go...
#25 |
oops...I have washer tank..not overflow. sorry. thought 71 didnt come with overflow...
