Old 07-20-2015, 02:08 PM   #1
iceman777
iceman777's Avatar
cracked steering wheel
hi has anyone got any tips on how to repair a cracked steering wheel and what to use ie epoxy putty
iceman777 is offline   Reply With Quote
Old 07-20-2015, 03:32 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: cracked steering wheel
I use PC-7 two-part epoxy that, when mixed correctly, sets up to be the same hardness as the original steering wheel material. I would recommend using a small die grinder to make a V-channel in the crack all the way down to the steel. I recently reduced the diameter of my steering wheel and had to do a few repairs to some cracks on the lower ring and around the hub at the same time:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-20-2015, 04:37 PM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: cracked steering wheel
Home - Steering Wheel Restoration - Steering Wheel Repair - Tips From Eastwood
http://www.eastwood.com/steering-whe...-from-eastwood
Steering Wheel Restoration Tips Episode 119 Autorestomod
https://www.youtube.com/watch?v=ej2k_xoxjIY
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 07-20-2015, 07:53 PM   #4
racecougar
racecougar's Avatar
Originally Posted by vin63 View Post
[COLOR="Navy"]I use PC-7 two-part epoxy that, when mixed correctly, sets up to be the same hardness as the original steering wheel material. I would recommend using a small die grinder to make a V-channel in the crack all the way down to the steel.
That's the same epoxy theastronaut recommends/used when cutting down his wheel.
http://67-72chevytrucks.com/vboard/s...=474456&page=9
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
