07-22-2015, 09:05 AM | #1 |
Sandalwood Steering Wheel Paint
Has anyone ever tried to paint a steering wheel to match the Sandalwood color? If so what type of paint and color code did you use? Pics and procedure would be great. Is it correct to assume that a '72 with parchment interior got a sandalwood wheel if the dash pad and column were sandalwood?
07-22-2015, 10:01 AM | #2 |
Re: Sandalwood Steering Wheel Paint
I'd like to see the responses to this one. I have the same setup, parchment interior, sandalwood dash, column, and steering wheel. Like most others, my sandalwood steering wheel has crumbled.
I've obtained a black oem steering wheel, and am considering painting a dash pad and this wheel to get the original look back.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
07-22-2015, 10:23 AM | #3 |
SWB 4x4 Collector
Lacquer or acrylic enamel would work. You will really want to scrub the grains of the steering wheel out and wipe down with wax and grease remover.
Acrylic enamel with hardener would be more durable than lacquer. I have seen good results of people on here using the single stage paints on their wheels. You will want to get the paint mixed at a paint shop. Usually you can bring in a sample of the color you want to match and get what you need. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
07-22-2015, 10:46 PM | #4 |
The reproduction wheels are painted. As Trevor said, proper prep is paramount with the texture and considering the use. There are adhesion promoters like Bully Dog as well. Definitely a single stage automotive grade paint.
