Old 07-26-2015, 02:19 AM   #1
jadedbird
jadedbird's Avatar
Just how low can you get with a basic c knotch
Im planning on running a basic air ride system....
no seriously. really basic. so basic that if i need to add some air, ill have to run to the gas station or use a little pre-filer compressor. (i dont plan on playing with the ride height much)
I was wondering JUST how low can you go with a basic c knotch like the bolt in kits from cpp. i dont want to lay frame, but the 3/5 drop with 2" blocks just arent enough for me. so i was wondering if anyone has bagged their truck without dishing out the time and cash to modify the whole frame.
the front will be bagged on the stock a arms. yes i know they arent as flexible as the tubular aftermarkets.
pics?
jadedbird is offline   Reply With Quote
Old 07-26-2015, 07:06 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Just how low can you get with a basic c knotch
If you C-Notch the rear - your rear end at the third member may hit the bottom of the bed before the axle tubes bottom out at the c-notch. Try it.
Your front end can go as far as you want until the cross member hits the ground. But as you eluded your upper ball joints may be over-stressed at that point.
Old 07-26-2015, 10:34 AM   #3
LVPhotos
LVPhotos's Avatar
I am limited by shocks but still 2" more can be had. The pumpkin already pokes through. This is a 62 frame. So technically this would be frame contact without notch. I see no need for one if you set bump stop to keep rear out of contact.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 07-26-2015, 10:43 AM   #4
LVPhotos
LVPhotos's Avatar
Here is ride height. Before Porterbuilt front. 295 / 45 / 18 rear 235/60/15 front and torsion bars cranked. No tub cutting or rub. Still My Rear Ride Height. Still on Schrader valves.
Old 08-28-2015, 03:32 PM   #5
jadedbird
jadedbird's Avatar
that looks real good. nearly perfect
Old 08-29-2015, 12:40 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm at about 6-6" drop static on a weld in notch (not their notch, but similar in size), and I'm well before hitting either the notch or the bed. IMO looks like with the 12bolt I've got, it would probably hit first on one of the bed cross braces.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-02-2015, 09:10 PM   #7
jadedbird
jadedbird's Avatar
well I planned on raising the bed about 6" just because I like the shallow bed better. but maybe ill just have to go ahead with a mild c notch just to be safe
Old 09-04-2015, 04:12 PM   #8
creep
Registered Loser
creep's Avatar
You could always put on the air ride then see how much notch you want or need.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 09-04-2015, 09:40 PM   #9
LVPhotos
LVPhotos's Avatar
2" more to gain in rear with shocks limited travel. Bumper before frame!
See if this link works. https://m.facebook.com/justin.herrer...4994686574726/
