Old 09-07-2003, 10:34 PM   #1
beeroh
which engine do I have
I am not sure which engine the truck has. Is there a sure way to find out?
It has blue valve covers,
v8
not sure if its a 350 or 305
are there any numbers on the block that could tell me?
84 Silverado,
beeroh is offline   Reply With Quote
Old 09-07-2003, 11:10 PM   #2
Russell
Professional Grade
Russell's Avatar
if you look at your dash from the outside, then you'll see a number stamped onto a little metal plate, this is called a VIN, or vehicle identification number, then find a VIN decoder online and you can find out what type of engine your truck came with from the factory.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-07-2003, 11:14 PM   #3
beeroh
the engine isn't stock
there is supposedly an engine that was installed three years ago
84 Silverado,
Old 09-07-2003, 11:22 PM   #4
Russell
Professional Grade
Russell's Avatar
Hmm, there may be a serial on the block, I doubt that someone would install a 305 though, I would guess it to be a 350, but yeah, check the block for any information...
Old 09-08-2003, 01:13 AM   #5
68 Stepside
huh?
68 Stepside's Avatar
in front of the passenger side head, or behind the alternator in other words, there's a small pad. About 1" by 4" or something along those lines. There should be a bunch of numbers stamped into it. If you can get those numbers, we can tell you what the engine is.
Good luck.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
