Old 07-28-2015, 03:18 AM   #1
dwmitchell61
Wiring diagram for 1973 C20 Crew Cab?
My gal has a 1973 C20 Crew Cab. It originally had the 454ci in it. Someone had swapped that for a 350ci small block engine which is getting tired and the transmission is a goner.
She bought a 1988 Canadian GMC C1500 with a 305ci small block and TH400 heavy duty transmission (maybe a 454 can go back in there in the future).
I am in the process of cleaning out the '88 TBI/engine compartment wiring harness and getting it ready to go into the '73. I am needing to tie into the Park/Neutral switch for the ECM & brake switch for the downshift relay. I also need to tie into the ignition switch "run" lead.
Can anyone supply me with a link to a wiring diagram for the 1973 Chevrolet C20?
Thanks in advance for any help offered...
Dave
dwmitchell61 is offline   Reply With Quote
Old 07-28-2015, 01:55 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Wiring diagram for 1973 C20 Crew Cab?
Dave
Look in my signature...
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-29-2015, 12:31 AM   #3
dwmitchell61
Thumbs up Re: Wiring diagram for 1973 C20 Crew Cab?
Cool!
Mooch-o grassy ass, Sir! Just what the doctor ordered.
I am going to see if I can locate a second junction block like the 1988 had on the firewall for the BATT + distribution.
I will power the second from a relay energized by the '73 IGN RUN lead.
I have to use the Park/Neutral switch to run a DPDT relay to safety the IGN START lead and send a signal to the ECM for P/N status.
I also have to run a relay from the brake light circuit to kill the power to the downshift relay when the brake pedal is depressed.
The 73 has dual tanks, so I need to replace the tank selector solenoid with a 6 port one so the return line has a route back to the proper tank. Have to install a tap in the filler necks to connect the returns to.
The TH400 transmission we are installing is a heavy duty model, has the HD on the bell housing. I am hoping the yoke on her drive-line has the proper number splines.
I will have to remove the reluctor in the transmission for the speed sensor and install the appropriate speedometer gears & sleeve for the tire diameter so the speedometer will work, then get a VSS sensor to go between the gears & speedometer cable to send the VSS signal to the ECM.
I don't think she realized just how much work the project would be!
