Old 07-28-2015, 10:59 AM   #1
Guss
RnD Fab, LS3, Which radiator hoses?
I have spent a couple of hours on here looking for radiator hose recommendations but have had no luck. As in the title, I have a crate LS3 and an RnD Fab radiator. Having lots of trouble finding radiator hoses. I have been going cross-eyed looking through the Gates catalog also. Any help would be GREATLY appreciated.
Guss is offline   Reply With Quote
Old 07-28-2015, 12:22 PM   #2
cooperhw
cooperhw's Avatar
Re: RnD Fab, LS3, Which radiator hoses?
What I did when I installed my LS-2 in my Chevelle was measure each opening and make a little sketch. Then I used a soft brazing rod and bent them to the correct angles. Once I got my angles correct I went down to the local parts store and asked if I could look through the hoses. Took about an hour to get two that were close and brought one back for a longer one if I remember.
JMO
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 07-28-2015, 07:09 PM   #3
68shortfleet
I am using an aluminum radiator with stock location and size inlet/outlets with my LS1, so my info may not be relevant to your swap.
A Gates 20931 lower hose fits extremely well for my engine placement.
68shortfleet is offline   Reply With Quote
Old 07-29-2015, 09:44 PM   #4
Did you look in the LS swap forum. That's your best bet.
Old 07-30-2015, 12:05 PM   #5
Aruba1
I have an LS engine and a stock C20 radiator. For the upper hose I used the stock 2000 Tahoe radiator. I had to apply for some heat to the radiator opening portion as it's wider then the stock tahoe radiator but it worked fine. For the lower radiator hose I went to a local old-fashioned NAPA store and they let me look through all their hoses. I ended up purchasing 3 different hoses and then returned two hoses at a later date. It all worked fine. As long as your RnD radiator has the same diameter ends and same build as a stock radiator, you should be able to use the stock hoses.
Aruba1 is offline   Reply With Quote
