Old 07-29-2015, 06:54 PM   #1
blazercrazy70
blazercrazy70's Avatar
Needing help on which ac bracket to use
I am putting in a LS motor with ece motor mounts and wondering if I can use lower ac bracket or do I need the mount in the upper position
blazercrazy70 is offline   Reply With Quote
Old 07-29-2015, 07:56 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Needing help on which ac bracket to use
Most of the after marker compressors do allow enough room with the stock compressor. You can get the Holley LS brackets that look stock but hang the ac compressor up higher
Old 07-30-2015, 05:49 AM   #3
30 a truck
30 a truck's Avatar
I used Zoops on this LS in a 30 A truck.
30 a truck is offline   Reply With Quote
Old 07-30-2015, 10:23 AM   #4
cooperhw
cooperhw's Avatar
I put an LS in my Chevelle and tried to use the low mount compressor. Even notched the frame to allow it room. Ended up calling Kwik and bought one of there kits with compressor included that mounted it up high on the passenger side.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 07-30-2015, 12:26 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Needing help on which ac bracket to use
LS1 brackets.
This is what I used in my 71 C10.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
