07-29-2015, 11:11 PM | #1 |
Looking for exhaust manifold(s) for 1971 Chevy 402
71 Chevy, SWB, 2WD, 402
Looking for a flawless. Finish doesn't matter, I can have that done. Seems I need at least the RH side without A.I.R ports. I may also be interested in a pair. The part numbers for not A.I.R. are: 3994045 LH 333846 RH I may also be interested in a pair with A.I.R. ports (plugged up), or at least the LH side. One of the manifolds was replaced, and if I remember right it was the LH side. In other words, my manifolds don't match. The part numbers for A.I.R. type are: 343787 LH 353030 RH Incidentally, this truck never had the A.I.R. pump. I don't believe these were replaced before I replaced the one, so if it was the LH side that was replaced, then GM slapped on the A.I.R type w/o it having the an A.I.R. pump. Has anyone seen this? Anyone know the history on A.I.R. emissions? I think I've read that was beginning 1972. I suspect whether or not a truck had A.I.R. varied by State regulation.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-29-2015, 11:31 PM | #2 |
Re: Looking for exhaust manifold(s) for 1971 Chevy 402
I may have one or a pair with the A.I.R. ports. I will double check what I have if you are interested.
Paul |
07-29-2015, 11:34 PM | #3 |
Thanks Paul. Unless I discover the A.I.R. is wrong for this truck, I'm interested.
07-29-2015, 11:55 PM | #4 |
mine are
3994045N
Pancho 69 c/10 step side 454/400 with 3.07 |
07-30-2015, 04:27 PM | #5 |
I tried to upload some pictures. I was unable to, got a message saying a security token was missing. Send me your email and I will send you some pictures.
Paul |
