Old 07-30-2015, 12:59 AM   #1
akart
Tight bolt to steering unit
The high pressure line to my steering is blown. Can't loosen the fitting on the end of the line. Have tried knock'er loose fluid and have a line wrench. Very tight and I don't want to booger it up. Any suggestions? Heat?
akart is offline   Reply With Quote
Old 07-30-2015, 04:11 AM   #2
chengny
chengny's Avatar
Re: Tight bolt to steering unit
If the hose is blown, its trash anyway. Get it out of the way.
Use an imp (mini tubing cutter) and crop the steel tubing as close to the fitting nut as possible. If you can't spin even a mini cutter, use a hacksaw blade or sawzall.
Then, with no tube sticking out of the fitting to deal with, the nut can be grabbed with a box end wrench or 6-point socket.
chengny is offline   Reply With Quote
Old 07-30-2015, 09:22 AM   #3
69heavychevy
69heavychevy's Avatar
I had to do exactly the same thing. The fitting was so tight that I started to round it off with the line wrench. If you have a long ratchet that will help with getting some good leverage.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
