![]() Join Date: Apr 2010
2002 LM7 Swap - No Start
Guys, I'm hoping to gain a bit of help for a no-start condition I have on a swap I am doing in my 70 CST. Fuel pump is fine. I get plenty of gas to the rails. I have removed and replaced the injectors as the original ones were clogged. Next, I poured a bit of gas into the intake...not even a sputter. Then, I removed a spark plug...no spark. I'm inclined to think that the ECU isn't sending a signal. All wiring from custom harness is connected to the correct sensor/bank. No spark.
Any info is much appreciated!
John Paap Ole Greenie Hagerstown, MD My Mistress 70 CST Short/Step LS 5.3/4L65E New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773 |
Re: 2002 LM7 Swap - No Start
Was the computer reprogrammed? Are the injectors firing? Sounds like vats wasn't disabled.
Also Im going to move this to the LS section for you to get some more responses.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
![]() Join Date: Sep 2005
Try running a ground wire to the ecm case and see what it does.
Check your grounds in the harness and make sure they are clean and tight. If VATS isn't disabled it should start and die. In an original harness there are two grounds at the rear of both heads, and one up front down low behind the power steering pump, this is the one that controls the coils.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Okay, I did a bit more checking...
1) I checked all the grounds...GTG 2) I checked the power lead to PCM and the accessory wire too. I found that the PCM requires a continual 12V for ACC wire through the cranking cycle. There is no where on the OEM fuse block that can supply 12V from ACC to Cranking and then back. I managed to connect a switch to 12V. Essentially, I'll flip it on when I want to start the engine. Is there a wire location and color, that is original to the truck that I can tap into that would provide this signal? BTW, This thing runs awesome. New cam, DT headers, no cats...you know the deal. ![]()
#6 | |
![]() Join Date: Jul 2009
EDIT: I should mention that if the wire mentioned above was powering a points type distributor before the engine swap, it is probably a resistance wire and should be changed for a "regular" wire to get the full 12V that you need. |
#7 | |
