6.0LS + 6L90e is worth?
I'm kicking the tires on upgrading my motor.
Upgrading the motor, why not upgrade the trans too? I have a 1973 Suburban 350/350/205 which all works fine, but it gets crappy mileage and feels kinda underpowered. Would be kinda nice to pollute less and get better mileage AND have more power. I found a Ultra low mile 2014 6.0 ls motor & 6L90E trans. but the guy is asking $8,000 for it. Comes with all accessories: ECM, wire harness, All engine accessories (AC), PIM module & APP Sensor. I found plenty of cheap 5.3 motors, but when you do the math after you buy all the "Small" things, you can probably get to close to half this number (for a stock 5.3!) Not sure if the 6L90 is 4wd or 2wd or if that matters? |
Re: 6.0LS + 6L90e is worth?
Save some money and grab a 6.0 LQ4 with a 4l80e and you will be way ahead for it. Great motor coupled to a strong trans with many possible upgrades.
Science flies you to the moon; Religion flies you into buildings. LeMans Turbo build http://ls1tech.com/forums/forced-ind...rbo-build.html C10 build (twin-turbo) http://www.performancetrucks.net/for...didate-501987/ |
![]() Join Date: Sep 2005
Its not a bad price but the newer motors the harnesses are running like 2700 dollars go with an older 5.3 or 6.0
![]() ![]() Join Date: May 2015
Yep go with the older 5.3 or 6.0....yes it will matter if its 2 or 4wd..you will need an adapter to go from a ls 4wd trans to the 205 and those get pricey very quick..would be simpler/cheaper to use your t350 or go to a t400 adapted to a ls
A 2014 wouldn't be an LS engine, it would be a new Ecotec. Are you sure about the year? The new engines are direct injected, and not many people have done that swap just yet.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
![]() Join Date: Sep 2013
