07-31-2015, 06:15 PM | #1 |
6 bangor, 3 speed column to 350 turbo 350 small block
Hello, need info on what mounts are required to do a small block install on my 69 Blazer. Has three on the tree and a six now. Also does the 350 trans bolt right up? Any help would be greatly appreciated!
08-02-2015, 11:11 AM | #2 |
Re: 6 bangor, 3 speed column to 350 turbo 350 small block
Should not be bad, I am sure someone will chime in if I am not correct but the engine crossmember and towers for a sbc bolt in should be able to purchase them on the for sale forum fairly easy. I am not sure what the tranny transfer for a 3 sp. looks like but should be another bolt on and easy to purchase on the forum. The column and shifter linkage again is all bolt on stuff so like I said should all be fairly easy. I may have some of the stuff you need can look if interested.
08-02-2015, 11:35 AM | #3 | |
08-02-2015, 11:37 AM | #4 |
Thanks for the info! I have the column. Will need the shift linkage if you have it. Thanks!
Posted via Mobile Device |
08-31-2015, 02:52 PM | #5 |
Sorry I totally forgot about this do you still need the stuff?
08-31-2015, 03:00 PM | #6 |
[QUOTE=1rippen6;7293910]Sorry I totally forgot about this do you still need the stuff?[/QUOTEI
Hello, I do need everything except the column. Posted via Mobile Device |
09-01-2015, 08:42 PM | #7 |
I thought the 1970 Blazer 2WD 6 cylinder with 3 on the tree was rare. How rare is a 1969? Where do they keep these?
09-01-2015, 09:27 PM | #8 |
That is weird I didn't get a notice that you posted I will look tomorrow and see what all I have.
09-02-2015, 08:10 AM | #9 |
That is a really rare combo. The engine mounts can be had I believe from lmc or brothers. Or someone parting out a truck. Easiest way would be to buy a cheap parts truck and get everything out it that you need. How good is the engine and trans that are in it? Also,you got pics?
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
09-02-2015, 09:33 PM | #10 |
Sorry it took so long maybe I missed it but is your truck 2wd? The stuff I have is from a 4wd should be the same but I am not 100% sure. The pivot pin has some wear but I will and blast and fix that before shipping. 45 plus shipping send your zip if interested and I will get you a quote.
