Old 08-02-2015, 03:17 AM   #1
69 MOD
69 MOD's Avatar
Convert to Electric Oil Pressure Gauge?
Tried some research (search button) but haven't seen anyone who has said what parts to use to convert the mechanical pressure gauge to electric.
Has it been done on a stock dash?
I would really like to make the conversion and was thinking the 80's gauge would probably work in the slot.
Thanks,
MOD
Chad
'71 GMC 2500 Custom Ol Blue
'72 Custom Deluxe Highlander Stuffed Olive
'73 Trans Am
'13 Silverado 2500 Duramax Storm Trooper
69 MOD is offline   Reply With Quote
Old 08-02-2015, 12:35 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Convert to Electric Oil Pressure Gauge?
You will have to run the gauge seperate from the rest of the gauges. Buy the sendor and pressure switch and run wires to the gauge.
The silver cylinder above brake booster is the pressure switch. This was in my old setup. Tubing from back of intake to switch then wired to gauge in the truck.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-02-2015, 05:43 PM   #3
davepl
davepl's Avatar
Factory electric setups were used in the B-Bodies of that era. You'd need an actual gauge that fit, but you could still use factory senders and so on. PM me for part numbers or whatever you might be missing.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-02-2015, 08:12 PM   #4
leftybass209
leftybass209's Avatar
You can use the oil gauge from the square bodies, when they switched to electric. The plus side to that is you can modify the gauge to accept your original face, to retain the original look of the dash. That is going to be my next mod. Best of luck, whatever you choose.
leftybass209 is offline   Reply With Quote
Old 08-02-2015, 11:21 PM   #5
69 MOD
69 MOD's Avatar
Thinking that I'm going to try to put a '78-up electric on the factory spot, I'll post it here to show the process...
Time for a parts search...
Thanks guys,
MOD
Chad
'73 Trans Am
Old 04-11-2016, 01:34 PM   #6
brian1971
brian1971's Avatar
Hi 69 Mod,
Seeing if you ever did this conversion and if so do you have any pics on how it turned out.
Thanks Brian
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
