Old 08-02-2015, 06:11 AM   #1
fs64
Ram horn manifold help please
I am looking at used Ram horns and am finding different styles available. Some exit straight down and some are angled. I would assume the angled ones would help with bending the rest of the exhaust pipe but have never seen pairs available where both are angled. Also is the heat riser piece necessary?
Thank you for the help and assistance, Todd
fs64 is offline   Reply With Quote
Old 08-02-2015, 08:47 AM   #2
geezer#99
geezer#99's Avatar
Re: Ram horn manifold help please
THe only time there where angled pairs was for dual exhaust trucks. One down and one angled was single set up.
Heat riser could be necessary if you run your truck in cooler weather. Helps with intake warm up. If you're doing a stock as a rock resto you'd want the riser.
Are you running a stock motor or modded with cam, intake, carb etc?
Old 08-02-2015, 09:35 AM   #3
fs64
Stock fuel injected not concerned with needing the riser. Was concerned if there is a flange that will accept the exhaust pipe on the manifold if you don't use the riser.
Old 08-02-2015, 09:43 AM   #4
geezer#99
geezer#99's Avatar
Can be done.
Muffler shop can set you up.
IIRC the angled ones had a recess in the outlet for a doughnut type gasket.
Old 08-02-2015, 02:20 PM   #5
LVPhotos
LVPhotos's Avatar
Here are some "new" choices from Speedway Motors.
http://www.speedwaymotors.com/Search...rn%20manifolds
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-02-2015, 03:18 PM   #6
LDO
LDO's Avatar
Is there any advantage to using the angled ones over the one that exit straight down?
LDO is online now   Reply With Quote
Old 08-02-2015, 04:16 PM   #7
LVPhotos
LVPhotos's Avatar
Clearance of crossmember and frame.
Old 08-02-2015, 07:01 PM   #8
AcampoDave
AcampoDave's Avatar
Straight downs seem easier to find and they can be made to swap side to side.
AcampoDave is offline   Reply With Quote
Old 08-03-2015, 09:36 AM   #9
doobiebro
doobiebro's Avatar
Cant go wrong with the ones Speedway has that was posted by LVPhotos.. I used two sets - used sandblasted them and brushed manifold paint from Eastwood and they hold up good and they dont leak like headers do! Heres some pics of two builds I used them on and straight dumps is the best way to go for clearance in my opinion..
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 08-03-2015, 01:03 PM   #10
LDO
LDO's Avatar
anyone use these, 15 bux cheaper...
http://www.ebay.com/itm/201261003215...%3AMEBIDX%3AIT
Old 08-03-2015, 01:24 PM   #11
MikeN
MikeN's Avatar
I use rams horns on my 64 C10 with a 350. Both of mine dump straight down. On the LH side I use a nice used original I bought from a fellow member here, and on the RH side I use a reproduction I bought from Crane's Corvette Parts. I went this route because A) both are the larger 2.5" outlets, and B) the LH side has the correct mounting boss for factory alternator brackets and the RH side has the correct mounting boss for factory A/C. I'm very pleased with the results. Looks good, sounds good, and none of the headaches associated with headers.
MikeN is offline   Reply With Quote
Old 08-03-2015, 03:58 PM   #12
ProudSoul
ProudSoul's Avatar
http://www.ebay.com/itm/121583031716
I used these angled ramhorns on my 63. Work great and were cheap!
ProudSoul is offline   Reply With Quote
Old 08-03-2015, 04:08 PM   #13
thomas_a_reed
thomas_a_reed's Avatar
I went with Dorman 674-501 because I could get them thru work pretty reasonable..
66 CHEVY STEPSIDE 2WD W/283 ( FAMILY HAND ME DOWN)
81 CHEVY SHORT BED 2WD W/250 4SPD TRANS STRAIGHT 6 ( CURRENTLY UNDER CONSTRUCTION)
01 SILVERADO SHORT BED 2WD W/4.3 5SPD TRANS ( DAILY DRIVER) Sold
03 SIERRA 4X4 STEP SIDE EXTRA CAB 5.3 AUTO( NEW DD)
09 CHEVY COBALT W2.2 AUTO (GF'S DAILY DRIVER)
thomas_a_reed is offline   Reply With Quote
Old 08-03-2015, 04:39 PM   #14
markeb01
Senior Enthusiast
markeb01's Avatar
I used an angled manifold on the drivers side, and a straight manifold on the passenger side. Both have loads of room around them.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
