08-03-2015, 02:00 AM | #1 |
Stereo system from scratch
Hello, I have a 61 c10 and I'm looking to do a complete stereo system on it but this is not my area of expertise, can someone give me a list of all the things I need to complete the system. I have nothing now so I'm starting from the bottom, but I do have a new wiring harness so I can wire this.
Thanks, Ethan Posted via Mobile Device |
08-03-2015, 08:28 AM | #2 | |
Re: Stereo system from scratch
multi channel amp 5 preferred with built in crossover- JL audio decent cables- RCA interconnect-speaker-turn-on lead- buy an amp kit 4in coaxial speakers for the dash- depends on the rest of the truck for size i have 1 ten inch sub Fat Mat - inside doors ,under dash,cab corners,anyplace you cant see it. here is my system
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
08-03-2015, 08:31 AM | #3 |
08-03-2015, 11:52 AM | #4 |
Thats a nice setup you have there Jim!
Im just about done with mine. But its not that fancy!
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE |
08-03-2015, 01:12 PM | #5 |
Old member
Never thought about a solenoid for the power cable to the amps. Hmm I may add one to my setup. Interesting.
Here is mine. 2 Memphis gold 10 shallow subs. 2 mid ranges in the dash Memphis golds! Cab corner mounts that I modified and installed 3 ways in. Head unit. I did the hush mat in mine with bubble wrap on top then the carpet. The mat is inside the doors also. Amps are inside the console and everything is nice and neat inside the truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
08-03-2015, 02:29 PM | #6 |
thank you. was not cheap after i install the new Focal tweeters and the 2 monoblock class A Monolithic amps to power them I will have $5,000 invested. I used to compete back in the 90`s and now im getting back into it.
08-03-2015, 07:42 PM | #7 |
Here's a little tutorial from a different forum. I plan using this idea in my truck.
http://www.jalopyjournal.com/?p=11082
'62 C10 LWB fleet side. 283 w/ a T5 |
11-13-2015, 03:24 PM | #8 |
Sub'd in.
