trying to find a rear only air bag kit
I have a 68 Chevy short wide, with coil rear suspension. I plan on doing a set of 2" drop spindles in the front.
It would be nice to get the rear down 4 to 5 inches and still be able to haul the dirt bikes or the Harley in the back, perhaps a small trailer too. Air bags seem like just the thing. low when empty, pumped up when hauling and slammed for loading bikes (better load angle). I assume I would need some fairly heavy bags, as I still plan to use it like a truck. Also, I'm not sure about drive line geometry, shocks, shock placement, panhard bar etc. I don't want to mess up my truck and not be able to haul heavy loads. The truck will normally ride 4-5" lower in the rear when empty, and pump the air bags up taller and stiffer with a load best options? |
#2 | |
Re: trying to find a rear only air bag kit
Shoot us an email and we can follow up and discuss your needs and recommend a system that will work best for your goals and budget! Typically we would recommend the bags with mounting brackets, a shock relocation system, and a new trac bar that will work in harmony with the drop and travel the air system will provide. You will also need a way to fill the air bags. You can go as simple as a schrader valve set up that you manually fill and deflate as needed, or an electric compressor and tank with valves to make it easier! Sales@pbfab.com Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
