63 Inline 6 - Which Radiator?
Hey Everyone,
Let me start by saying that I rarely post on here, but I read what others ask about regularly and I've learned a great deal along the way. So, thanks to everyone for the help! Here's my dilema. I have a 63 with a 250 inline 6 in it, along with the stock radiator. I've removed the 4-blade belt driven fan and installed a 16" electric pusher (I used it as a pusher rather than a puller due to clearance issues). I don't have a temp gauge, but I'll still the the red "hot" light in traffic, or sometimes if I'm putting a load on it during a hill climb or something like that. I'm not sure what temp triggers the light, but I know it's warm because it spits over some coolant when the light is on. I've been looking at a champion radiator and, after talking to the company and one other who sells them, they seem to think their version of an aluminum 2 row designed for an inline 5 should keep my truck cool. They claim it'll cool to 350hp and I obvioulsy don't have anything close to that! Does anyone have any first hand experience with an aluminum 2 row? I'd rather stick with one of those if it'll be enough because it'll mount right in. Any help would be much appreciated!! p.s. I think some of my problem was timing/tuning that I've since fixed with an HEI distributor - wow what a difference! But I still want/need a new radiator. Thanks everyone! Jerry ![]() |
Re: 63 Inline 6 - Which Radiator?
Jerry, I have had the Champion 6 cylinder radiator in my 1964 with 230 for the past couple of years, and have never had a problem. It looks good and cools well.
I've been so happy with it that I just bought the 3 row V8 version for my 350 swap! Tim |
![]() Join Date: Jun 2011
i just did a champion 4 core last month. 16in fan pusher same reason no clearance. the fan comes on at 190 and my thermostat is 195. i have a 65 with the 230 six.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
#4 | |
Old Bleu - does your truck stay cool in traffic and all with that radiator in it? |
Yes, the truck has always stayed cool, even in the 90 degree plus heat that we have here in the summer. When I installed the radiator, I also installed a new water pump and flushed the system, so that might have helped too. I have a small overflow tank on it, and it has rarely ever spewed any coolant into that.
I have to admit though, that I don't do a lot of stop and go driving in this truck, but when I have, it has never given any indication of overheating. I also installed new seals around the radiator shroud when I installed the radiator to ensure that I got good airflow through the radiator. I'm in the process of a V8 swap right now, and considered buying a more expensive radiator for that, but the Champion has served me so well, that I went ahead and ordered another in the V8 size. I'm going to run an electric fan with this one since I am using a serpentine belt system on the V8. I'm probably a couple weeks away from having it back on the road, but don't expect to have any problems with the new setup. I'll try to remember to get back to you on the results. |
#6 | |
#7 | |
![]() Quote:
PLUS: I think a shroud will likely always increase an electric fan's effectiveness by a huge margin. One could be surprised by how much "lost air" rushes out a fan's un-guided, wasted path without a proper-fitting shroud--pushing OR pulling. Good luck with your decision. Sam |
#8 | |
How did the V8 swap go? I just purchased a 55 GMC. One of the previous owners put a 350 in it and did not upgrade the radiator. Seller admits it is only capable of short trips of 20-30 miles. Is the Champion system with electric fans the way to go? Did you go with 2 or 3 rows? Thanks, John |
As "air conditioning" was part of my restoration process I went with a 2 core aluminum radiator. Instead of electric fans I kept the original fan set up and had shroud made by local sheet metal shop. I also went with 180 degree thermostat.
No overheating problems even with the Stop, Set, Wait, Go and Stop again while cruising the Mississippi Coast during the annual week long vintage event. |
Take a look at these too. These are stamped to look and fit like your orig.
http://www.ebay.com/itm/KKS-3-Row-Al...21138e&vxp=mtr http://www.ebay.com/itm/KKS-3-Row-Al...21138e&vxp=mtr
'62 Chevy K10 |
#11 | |
Ok everyone, I'm still up in the air about a replacement radiator. As a refresher, I have a 63 with a 230 (or 250) inline 6. It has the stock 2 core saddle mount radiator that doesn't leak, but it also doesn't like the weather to get very warm. I ordered and received a champion aluminum 2 core (EC6066). It's very close to my original in overall height and width dimensions, but here's the problem...the tanks are wider (a good thing for cooling, but not mounting) on the new one so my saddle mounts won't fit around it. I have no doubt that I'm not the first one to encounter this problem and I know we have a lot of creative minds on here so please let me know what you guys have done to overcome this.
Thanks! |
I made new saddle mounts for the bottom of mine and a new mount for the top. I got a length if 1.5" wide flat steel at Home Depot, then cut it to length and bent it into the U shape in my vise with a 3 lb. hammer. I sized the new brackets to accommodate the original rubber isolation pads. I just bolted the new brackets in at the bottom. I made a similar mount for the top and attached it with rivets to a short length of the same flat stock that I bolted in the original holes. I painted it black, and it blended right in.
When I got my new V8 sized radiator, I used the same process to make wider mounts for it on the bottom, and then welded up some side mounts to hold it in along with the electric fan. I've been happy with both of my Champion radiators! |
#14 | |
