08-14-2015, 04:51 PM | #1 |
Brake lights and blinker. Help please.
Today I went through the process of rewiring all of my lights. I completely rewired the rear taillights harness with new wiring and I replaced the rats nest front light harness with a near perfect one from a donor truck.
How do the brake lights work? I followed this wiring diagram.. There is also a tan wire that I traced from the rear up to the firewall and it enters the cab. Does this wire connect to the brake light switch? How does that get wired into the brake light harness? All of my blinkers now work except for the front drivers side. Both rear blinkers work and the front passenger side works fine. All of the front lights light up when I turn on the lights but the driver side front blinkers will not flash at all. I replaced the flasher on the fuse panel and the 20A fuse looked good still. Any idea what is wrong with it? |
08-14-2015, 11:37 PM | #2 |
Moderator
Re: Brake lights and blinker. Help please.
The turn signal lamps use the same filaments as the brake lamps.
The brake light wire runs from the pedal to the turn signal switch in the column then out to the bright filaments in the tail lamps. This is a description of the same type switch in a Ford Mustang. The GM switch works pretty much the same way. http://1970mgr.org/_TurnSignals.htm
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 08-15-2015 at 02:53 PM. |
08-17-2015, 12:58 PM | #3 | |
08-15-2015, 08:04 PM | #4 | |
I worked on a car last week where the left front turn signal wouldn't work. Turned out that the two contacts in the socket (on brown fiberboard) were not lined up with the contacts on the bulb. Hard to explain, but I ended up re-keying the fiberboard and everything worked fine. Maybe not your problem, but worth a look.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 08-15-2015 at 10:14 PM. |
08-17-2015, 08:05 PM | #5 |
make sure bulb is in the correct position. make sure theres a good ground from harness to bed and bed to frame
1983 Scottsdale K10 496 /t400 fmvb /208 /D60 and 14ff with Locker /35x12.5x15 mt baja mtz 680hp/720ftlbs of NA fun |
08-17-2015, 11:57 PM | #6 |
08-18-2015, 02:52 PM | #7 |
1157 is usually the tail/turn/stop bulb.. its a double filament bulb..
on your diagram the lite green is the backup lights.. the brown is the tail lights and side marker lights.. yellow is left turn and stop lights dark green is right turn and stop lights.. that's purty normal on a chevy..
JJ 71 SWB 360 Th400 4.56 |
08-18-2015, 03:38 PM | #8 | |
08-20-2015, 03:23 PM | #9 |
x2
brake lights go thru the turn signal switch too.. see if you have brake light power thru the turn switch.. usually orange is power to the brake switch white is out of the brake switch to the turn switch on the column,, yellow and green out of the turn switch..
08-21-2015, 08:49 AM | #10 |
I just received a new switch in the mail. Next time I go home Im going to do some debugging and try and figure out whats going on.
08-22-2015, 08:02 PM | #11 |
let us know
03-29-2016, 02:39 PM | #12 |
Figured I would post an update to this thread. Went home over Easter break and finally got some time to work on my truck. I went through and wire brushed most all of the obvious grounds I could find. Also pulled the steering wheel and replaced the turn signal switch as well as the brake light switch. some ground wires under the dash were pretty bad so I replaced all of those. I know have working brake lights, hazard lights, right signal and left signal lights. My only issue is when I turn on my right signal the left side lights blink as well but very dim. After thinking, I remembered that I did not polish up the ground for the one side rear taillights so Im assuming that ground is what is causing this. Thanks everyone for the help. One step closer to getting my truck on the road.
04-01-2016, 05:44 PM | #13 |
wtg Will
yea sounds like a ground..
04-02-2016, 07:41 AM | #14 |
I went through similar issues with my '76 after replacing my right front fender.
I'd removed the ground wires going from the battery to the core support (I also replaced rotted battery tray), and after reinstalling everything, I had weak turn signal lights, good hazard lights, no high beams, etc. My problems turned out to be poor ground connections at the core support---- Hope your issues are that simple---- good luck! |
