08-15-2015, 12:20 AM | #1 |
Need some assistance picking a color scheme (again)
71 Chevy SWB, 1/2 ton, 2WD, 402
Option 1: I was set on two-tone deluxe in ochre/white. I have all the NOS moldings. The upside is I might like it a bit more, though I think I'd want to drop the frame, because to me it looks much better. The downsides are is the cost is 15% more the alternative (below). I'd also need to drill for the clips and such. And most of all, those moldings have to line up perfectly. The suspension will be new regardless. Option 2: Then there's the Ochre with the white top. This would match the SPID, though I may want to add tailgate molding only. I don't necessarily have to lower it, because I like both stances. I'd have to sell my moldings, but that's not a big deal. I have the stainless steel window frames and the paint separator. Pictures are below. The first is almost like cheatin. Looks flawless and in a showroom. Anyway, which would you choose if you "could afford" both? SS is not allowed to post, you ochre-hating *%$*$...... Option 1: Option 2:
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-15-2015 at 12:51 AM. |
08-15-2015, 12:27 AM | #2 |
Man of Mini-Talents
Re: Need some assistance picking a color scheme (again)
Option 1.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
08-15-2015, 12:58 AM | #3 |
What do you figure that drop is for the above two-tone? Again, that image is like cheating. If I knew for certain my build would look that good, no question, option 1. He's a member here. Not sure who.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-15-2015 at 01:04 AM. |
08-15-2015, 01:02 AM | #4 |
Man of Mini-Talents
Probably 5/7
My advice is to go ahead and do it the way you want it, you aren't going to be satisfied having "most" of what you want.
08-15-2015, 01:13 AM | #5 |
I've been thinking it might be nice to have a black bed. That 2-tone does. Wonder what it is, Black satin? I don't imagine it's a spray-in bed liner.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-15-2015 at 12:51 PM. |
08-15-2015, 09:18 AM | #6 |
I would opt for option #1 also if those are the colors you want. Looks great. Sprayed in bed liner too.
"Life is too short to drive a boring vehicle". Later, Wayne |
08-15-2015, 09:55 AM | #7 |
I like the cleaner look of option #2
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
08-15-2015, 10:08 AM | #8 |
BlahBlahBlah
One looks great. Two isn't a combo I think I've seen before, and I really like that one ... If I was doing it I would go with option two. And if down the road I wanted to get a little fancier I could easily change to option one.
And as an aside I would not go with those wheels ... ever. Way too many cars, trucks, and everything in between go with those. Id go with some new slotted mags, or some original style torq thrusts (TTO's) or even white steelies with small caps. LOL, there ya go, I just built your truck my way
08-15-2015, 11:39 AM | #9 |
there both nice. but in my IMO. I would go with option TWO.
08-15-2015, 11:42 AM | #10 |
I know that option 1 was the more expensive and deluxe option but for some reason I never liked the 2 rows of trim on the sides. Personally if you like Ochre I would go with option 1.
1971 Cheyenne Big Block Longhorn |
08-15-2015, 11:48 AM | #11 |
#2 with all the moldings (#2 is Rene's, one of my "aspirational" trucks...) Or solid ochre (last)
08-15-2015, 05:27 PM | #12 |
1
2 is too much Ochre. I should say 2 as I would buy the mouldings.....lol |
08-16-2015, 12:12 PM | #13 |
Wonder whose truck this is?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-16-2015, 01:23 PM | #14 |
I think you picked two great examples of the ochre/white paint schemes. Between the two options, I think option 1 edges the other out. Some colors look best in certain patterns.
Not to throw a slight wrench in the works, but; have you thought about the other paint scheme that had white below the lower belt moulding, no top moulding, and a white top? I don't recall seeing that version with ochre. Best of luck with your decision! |
08-17-2015, 10:08 PM | #15 | |
Who the heck owns that Chevy two-tone? I'm curious about the drop and the "bed-liner".
08-18-2015, 01:08 AM | #16 | |
Moderator
Rene, if you are reading this chime in
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-18-2015, 04:07 PM | #17 |
Option 1.
My 72 GMC is the two tone deluxe ochre/white, and I was wondering the same thing as you. Since all of my side trim is missing, I thought option 2 would be easier. But I personally do like the option 1 best, so I'll have to buy trim. |
08-18-2015, 05:30 PM | #18 |
65 C20 292 4spd 4:56 Eaton HO52 |
08-19-2015, 11:55 PM | #19 | |
I bought NOS all the way around. Clips and all. Wasn't cheap. Some sweet deals along the way, most at a premium. Other than two pieces that have since been replaced, all mint. There's another option, which would be about 20-30% cheaper for moldings. I hear good things about MAR-K. Regardless, I'm back on the two-tone train and not looking back. Just need to figure out the right drop for the rear leaf springs.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-20-2015 at 12:06 AM. |
08-16-2015, 02:22 PM | #20 |
#1, but needs different wheels. Bedliner is a good thing
08-16-2015, 02:43 PM | #21 |
Moderator
Two tone deluxe of course
08-16-2015, 06:00 PM | #22 |
08-16-2015, 06:03 PM | #23 |
Option #1
08-16-2015, 06:12 PM | #24 |
20' Daredevil (Ret)
"Whichever you prefer, it's your truck" is way too easy, and you did ask for our opinions. Option 2 is nice & clean, but option 1 really pops, it's a sharper look IMO.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
08-16-2015, 06:15 PM | #25 |
I'd go with option 2 and get it down lower.
