Old 08-15-2015, 07:40 PM   #1
Kevin McPherson
Kevin McPherson's Avatar
Door weatherstrip questions
Is there supposed to be a channel, that holds the rubber weatherstrip over the door, on the fiberglass top of a blazer? If so where can I find some?
Kevin McPherson is offline   Reply With Quote
Old 08-15-2015, 08:23 PM   #2
Kevin McPherson
Re: Door weatherstrip questions
This is a picture of the area in question.
Old 08-15-2015, 08:25 PM   #3
Kevin McPherson
It is a double wall top if it matters
Old 08-17-2015, 09:13 AM   #4
jaros44sr
jaros44sr's Avatar
if you clean that area up, you will see 3-5 holes that the retainer 'T' clips sit in
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-17-2015, 06:50 PM   #5
Kevin McPherson
Thanks for the advise, as I saw the holes, and saw a metal channel in a picture of another blazer.
Old 08-16-2015, 10:00 PM   #6
Blazerowner
Blazerowner's Avatar
I am unsure on the double wall by there is a channel on my single wall. I used to have a double wall top blazer about 8 years ago and I don't think it had the channel. I believe it just glued to the top.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 08-16-2015, 11:32 PM   #7
71jimmy
71jimmy's Avatar
Double wall tops use retainer clips. LMC p/n 30-1601.
I believe it's advisable to use weather strip adhesive also.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
