Old 08-19-2015, 04:13 PM   #1
joey8383
joey8383's Avatar
Building my own fuel cell for LS swap
Wanting to attempt to build my own fuel cell since I have all the aluminum, break, welder etc here to do it. The Boyd tanks are extremely http://www.fueltankparts.com/replace...3-72-c-10.html and I'm wanting to build something similar, although it will probably end up being just a little more simple. My question is where to find all the fittings to weld on to the tank? I want to run an in tank pump big enough to run my 80lb injectors on a mild turbo build. Where can I buy the fuel pump flange, the threaded portion of the filler neck with cap, and sending unit insert?
Thank for any help
joey8383 is offline   Reply With Quote
Old 08-19-2015, 04:30 PM   #2
Taibo
Re: Building my own fuel cell for LS swap
Thank for any help
Godman Hi Performance in Memphis Tennessee has the weld-in tank bungs in aluminum. Pegasus Racing probably does as well.
Taibo is offline   Reply With Quote
Old 08-19-2015, 10:48 PM   #3
Jrainman
Jrainman's Avatar
you might also try filler neck supply . com
Jrainman is offline   Reply With Quote
Old 08-20-2015, 02:10 PM   #4
joey8383
joey8383's Avatar
5052 aluminum in .090 thickness should be fine, right?
Old 08-20-2015, 02:15 PM   #5
joey8383
joey8383's Avatar
Wow I guess I was searching the wrong key words. After googling "weld in fuel tank flange" and "weld in fuel tank fitting" I have found a million sources. I wasn't using the "weld in" term when I originally searched. Thanks guys
I will update this as a HOW TO when I build my tank next week with links to the fittings I buy and everything.
Old 08-20-2015, 06:19 PM   #6
Taibo
"weld in tank bung" would achieve the same results
Old 08-20-2015, 09:21 PM   #7
boraxman
Keepin an eye out
boraxman's Avatar
More power to ya if you can build your own...Paid over $800 from Boyd myself but that included in-tank pump, fuel sender, roll valve, etc./
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 08-20-2015, 03:49 PM   #8
boostedc10
boostedc10's Avatar
Boyd sells everything you need too.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
