Old 08-19-2015, 06:31 PM   #1
Brother Bob
Smile Replacing ALL the body bushings!
Howdy folks,
I'm currently, slowly with lots of cussing and busted knuckles replacing all the body bushings and hardware on my wifes 1972 GMC Jimmy 2 WD!
I bought the complete set of bushings and hardware from LMC and so far today I managed to get the back 2 out! LOL. All of them in this truck are shot, worn rust swollen and a ***** to get loose.
I was wondering if anyone has done this and if you have any tips to share?
I was planning on getting them all loose, hard ware removed and jack the body up and replace the ones in between the frame and body....then drop it down and install the hardware and lower bushings?
SO far I'm real good at busting bolts and cursing.
Any tips?
Thanks,
BB
No one gets out of here alive.
Brother Bob is offline   Reply With Quote
Old 08-19-2015, 10:03 PM   #2
BIG ORANGE
BIG ORANGE's Avatar
Re: Replacing ALL the body bushings!
I would just spray PB blaster on all the bolts then call me and let me know how much cash I need to bring over to take it off yr hands,,,,lol
Sorry couldn't pass that up.
Sounds like you got it figured out to me.
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 08-19-2015, 10:08 PM   #3
Brother Bob
LOL thanks buddy! Already soaking in PB and I'll go back in the AM ready to face the spiders, mud dobbers and rust and dirt falling in my face all day!
All of the body bushing are really rough and this GMC Jimmy is nice rig so I guess they are all factory.
Yea me!
BB
Old 08-20-2015, 01:27 AM   #4
franken
I have a little 3/8" breaker bar for just this sort of thing. I'm not a tool addict!
If there are cage nuts, break the bolt loose 1/4 turn. Turn clockwise 1/8 turn, then counterclockwise 1/4 turn. Repeat.
The threads jam and the cage nuts spin. Often the bolts are rusted and they shear.
Old 08-20-2015, 08:13 AM   #5
hemi43
hemi43's Avatar
With my truck, I cut the nuts off of the bolts with a cutoff wheel, then used an air hammer to vibrate the bolts out of their location. A bit of heat can really help too.
hemi43 is offline   Reply With Quote
Old 08-20-2015, 09:07 PM   #6
GMC-YA68
GMC-YA68's Avatar
every single one of my bolts were spot welded to the floor. Is that factory or did someone get lazy?
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 08-20-2015, 10:10 PM   #7
Brother Bob
MINE WERE TOO a light spot weld almost a brazed spot?
Got em all out today , I'll go back together in the AM. All the hardware was rotten as hell, most of the rubber was shot. I was surprised I had to pull the radiator to get the front two out....oh well.
Tips- Big impact to bust the nut or twist the bolt in half.
-Die grinder was really helpful with the spot welds on the heads of the carriage bolts.
-Buy the LMC kit complete with bolts and hardware- every part was there and right as rain. I think I paid 200 + bucks.
BB
Old 08-20-2015, 09:12 PM   #8
Blazerowner
Blazerowner's Avatar
I used an impact wrench when I replaced mine. They came off with ease but that was only on the carriage bolts. The regular bolts I just unused a large ratchet. If they are spot welded that isn't factory.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 08-20-2015, 09:22 PM   #9
BIG ORANGE
BIG ORANGE's Avatar
Mine are all spot welded in the bed area also,, lil PB blaster and they unscrewed nicely....
Good luck
Old 08-21-2015, 01:23 AM   #10
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
I just got done replacing them on my suburban.
Tips.. Clean the frame up and repainting/check for rust on top& bottom where the bushings sit. I put some rust converter on mine.
Replace one side at a time and while the body is jacked up put the bottom mount on loosely. It can shift a bit and make getting the bolts/sleeves in a bit of a pain.
I'll have a full writeup in my build thread tomorrow
68SWB4x4 is offline   Reply With Quote
Old 08-21-2015, 03:06 PM   #11
hemi43
hemi43's Avatar
Mine were tacked also !
Old 08-21-2015, 03:21 PM   #12
Brother Bob
All done! They have been played with before but not replaced..see the pics.
Cant believe that crap was in there! LOL doors close better now!
The Jimmy
Old 08-21-2015, 03:30 PM   #13
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
All of mine were tacked except the last two in the back. The two on driver/pass floorboard had a lot more weld than the others and the bolt sits below the floorboard, almost like a round divot so I had to be really careful cutting it.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 08-21-2015, 05:16 PM   #14
Ewr101
Ewr101's Avatar
How's the handling and ride now BrotherBob? Mine look about the same as your old ones!
72 Chevy 2WD Blazer
Ewr101 is offline   Reply With Quote
Old 08-21-2015, 08:53 PM   #15
Brother Bob
Couldnt tell ya honestly. I've had this one off the road for darn near a year.
Bought a new hard top for it and used it to brace the body so I could do the bushings. Just did a new rear diff and panhard bar....still need to take a trip through the brakes and find out why the P brake dont work?
Too much to do I guess and these SOB bleed us of money!LOL.
I've been steadily making progress though. My wife has owned this Jimmy for 16+ years and its tough to get her to stop driving it to do work and upgrades..
BB
Old 08-21-2015, 09:03 PM   #16
Brother Bob
Oh I forgot to add - I did these bushings back to front- I picked up the body under the tailpan up a couple of inches and was able to replace them all except the front ones in the core support.
I replaced the top bushings dropped the body down, used a rolling head bar to line up everything and jacked up the front and did the front two.
Easy peasy and was able to drop the bolts right in.
Hope that helps someone.
BB
Old 08-22-2015, 01:01 PM   #17
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Got my writeup done
Amazing how crusty these parts are that are holding the body on!
http://carmelvalleyclassics.com/2015...t-replacement/
Old 08-22-2015, 03:12 PM   #18
Jdubs71
Jdubs71's Avatar
Here's a useful thread that vtblazer posted a while back.
http://67-72chevytrucks.com/vboard/s...d.php?t=362908
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
