08-22-2015, 11:42 AM | #1 | |
Registered Truck Offender
engine dyno vs chassis dyno
I don't put much stock in the things printed is a multi-page book of paid advertisings,, (HotRod, Carcraft, Super CHevy etc) but a friend sent me this and it was quite interesting...
Sorry for the long and unformatted cut/paste read, but worth it just for something to think about... Quote:
In the end,, a Dyno (engine or chassis) is just a tool to get the motor in tune,, and if you expect any reliable calculated results at the drag strip (in anything but a $100,000 prostock chassis) Your kinda fooling yourself anyways. But this sure makes for an interesting read. https://540ratblog.wordpress.com/201...-test-ranking/ The whole page is worth a read if you have the time (especially the oil section)
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 08-22-2015 at 11:56 AM. |
08-22-2015, 12:01 PM | #2 |
Re: engine dyno vs chassis dyno
Dyno numbers are great for stuff to brag about. Every single dyno seems to kick out different numbers for the same engine even with the same correction factor. Im honestly shocked that in 2015 you still cant find an accurate dyno. It doesn't make any sense.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
08-22-2015, 04:16 PM | #3 |
I thought hp was figured by dividing peak torque @ rpm by 5252 or something like that. Dynos don't mean anything IMHO. Track tested is where it's at. I ran 12.2-4 @ 118mph with a 3800# truck. That's around 450-540hp depending on which calc you use. If I went off just the engine dyno hp I should run 10.1-3 @ 130mph or so. So going of dyno numbers I can tell people I have a 10 second truck. When in reality I have a 12 second slip and slide machine. I'm sure a 400hp car that hooks can hand me my ass from a stop. From a roll, not happenin..
At my worst I'm at my best Last edited by Hollow65; 08-22-2015 at 04:36 PM. |
08-22-2015, 05:04 PM | #4 |
I have a lot of time on chassis dynos and can tell you, one must read the fine print which most don't want to share.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
08-23-2015, 12:46 AM | #5 |
meowMEOWmeowMEOW
I've only used an engine dyno 2-3 times, and I always liked the "no BS" results. I know that there are still correction factors for temp and load, but not being able to argue things like parasitic loss and other less-quantifiable factors is nice.
I will say that the differences in result with DynoJet vs Mustang dyno's alone causes arguments and butthurtness in reputation. Mustangs tending to be "stingy" but lately I feel like they've been the most "Accurate" to expecations (if that makes ANY sense). Dynojets have always given me more favorable #'s, but with much less repeat accuracy. Have you guys ever tried those axle/hub-mount dynos? The ones where you bolt the rear hub up to a torque tube on an engine-dyno looking machine. They don't have the tire distortion or slip issues, but still get the rear wheel numbers. I haven't seen any big (8-900+) power cars run on one. If you consider those trailer-dyno's in the mix, they might as well be throwing numbers at a dart board. I will say that the excerpt kinda ignored the fact that those dyno's aren't locked to those correction factors.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
08-23-2015, 01:40 PM | #6 |
just IMO here but the ONLY important factor is getting a tune and monitoring the motor for ANY hiccup. If there is ANYTHING froggy it will show up on a good dyno measuring EGT in all 8, O2 in both banks, fuel flow for BSFC, monitoring oil temp/psi, water temp, air intake temp mass flow, bla bla bla.. and any bumps or dips in the torque curve through the rpm range. The actual number is somewhat meaningless unless your using the same dyno to compare changes in the motor / build.
Just like flow benches,, the Superflow computer controlled dyno / flow bench (like the 901+ series that controls the engines RPM sweep per sec) seems to be one of those that appears to be repeatable dyno to dyno. I'd like to think they will be consistent like the SuperFlo flow bench is. I had a set of heads flowed on Bischoffs flow bench in MI, then flowed in Tucson on another SuperFlo 600 series bench and was within 3cfm (@ 370cfm) Now that SuperFlow is getting into the chassis dyno it will be interesting to see how they compare to others out there for consistency. Flow numbers aren't everything just like data from the dyno. It's just one more 'tool' at our disposal to see if things are moving in the right or wrong direction
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
08-23-2015, 02:04 PM | #7 |
When was the last time someone here has been on a dyno? I haven't been since 99-00. Back then 10 seconds was real fast. Now we have 7 second street cars. If I made 642 then on an old school dyno, I'm sure my numbers are different today. Super73 spent a lot of time on a dyno trying different camshafts. I'm curious which one made more power and which went through the rpms faster? I've heard it's better to be able to rip through the rpms range than to be pumped about a peak number. The torque curve is where it's at.
At my worst I'm at my best Last edited by Hollow65; 08-23-2015 at 02:12 PM. |
08-23-2015, 07:32 PM | #8 | |
meowMEOWmeowMEOW
I've heard the conversation is even worse with diesel guys. They have been using them to put huge amounts of load onto the drivetrain so they can come up on huge boost #'s really early (without having to load up their own brakes). You can swing TQ #'s significantly by doing so.
08-23-2015, 02:46 PM | #9 |
Like Marv said my opinion is the same, dynos are for tuning and break in only, using as a tool to try different combos and settings, the numbers are for comparison on that machine only.
It's funny how I know of trucks that on the engine dyno their motor made 100hp more than mine yet on motor they run high 11's and on motor I run low 11's, weight likely about the same, I have a lighter front end they don't have a cage, both on slicks. Now I know setup has lots to do with that, but that's a large difference in time when I'm suppose to be making 100 less hp. Just comparing engine specs I know their numbers are bull****, but hey if that's what the engine builder told them and there's no way you can convince them otherwise they can quote numbers all day but in the end timeslips at the same track tell the truth.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 08-23-2015 at 02:53 PM. |
08-23-2015, 09:57 PM | #10 |
BR3 you think the diesel guys are bad.. And you REALLLy want to have fun.. let a owner of a C-5 /C-6 Vette tell you how the HP and Torque lines 'cross' at a lower RPM than our 'old school ' carburated cars. (rolling eyes)
I just smile and say "OooooKay then" (and think to myself... I should ask how much HP that new $2000 carbon fiber hood added)
08-24-2015, 12:25 AM | #11 | |
meowMEOWmeowMEOW
...and besides...I haven't had a carb in this thing in years
08-23-2015, 10:59 PM | #12 |
Isn't the dude that wrote that on chevelle tech? I read the whole thing, kinda overwhelming. Had some interesting thoughts on cam lsa vs overlap. Also the compression notes were a good read. Marv what did your engine put down? Ever test it?
At my worst I'm at my best |
08-24-2015, 12:11 AM | #13 |
Umm which one?
Of the latest I have races The 434 small block in the nova 797HP Runs 9.teens @ 145 in good air The 434 SBC I just took out of the truck, 666HP and that possessed SOB just came out and on an engine stand to learn some respect! Took the 3550 pound truck to 10.4's in 3500' air The old 383 I took out struggles to make 587HP The sand rail made 460HP LOL,, If you couldn't guess I spend a day tuning on the engine dyno getting the motor RIGHT,, then it's just small adjustments once it's in the vehicle.
08-29-2015, 10:56 AM | #14 |
mini truck racer
I try to get on a chassis dyno once a year . I don't care what the number is I just try to inprove it . I am more about getting the A/F ratio correct then anything else . I look at it like a controlled pass down the drag strip . I get a printout of whats going on and I don't have to drive it . Most of the time I can get 3 or 4 passes in a test and tune night . I usually have no problem getting 10 pulls in on an afternoon dyno session with jet/timing changes between pulls
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
09-03-2015, 01:19 PM | #15 |
It's Better With Nitro
With so many correction factors available by the dyne makers to skew power figures, I tend to also keep an eye out for a particular metric. I usually request for no correction factors to be used, and I tend to be more interested in the brake specific numbers through the entire RPM range of the pull.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
11-21-2015, 05:58 AM | #16 |
The fans in the room and how they get the air effects engine dynos. A trick that needs to be looked at are acceleration rates of the engine. In other words 2 engines can make the same power. The 1 that accelerates through the pull faster will be better. It's not just a h.p.measurement tool. You can make a lot of power with camshaft that are too big ,carbs to big manifolds and intake ports. Shows numbers and won't accelerate.
