Where to find filler neck hose for long bed 20 gallon saddle tank?
I cannot find replacement filler neck hoses for a 20 gallon tank. I have a 87 longbed that I used to have dual tanks on but I have switched to only one 20 gallon tank on my PS because of a LS swap. I cannot find any replacement hoses and the only ones I find use are just hard as a rock and dry rotted.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF 2020 1500 Silverado 3.0 Babymax 2002 2500 Silverado- 6.6/ Allison 2010 CTS V- The "NastyBuzzard" 1979 Trans Am - Eventually getting 6.0/T56 swap with boost |
Cruzzzn' Vet
Re: Where to find filler neck hose for long bed 20 gallon saddle tank?
![]() ![]() Join Date: May 2015
I'm not sure about what shape your hose needs to be but on mine I got oreillys to order me a long straight hose and I cut it to fit..the ones they stock were to short.
Malo classic industries only show hoses up to 78? I need the filler hose and the vent tube.
I can't use just s long straight hose has like a 90 deg bend.
www.lmctruck.com part# 32-3307 $19.95
#6 | |
Thank you, I appreciate it!
You're welcome.
Still trying to find out what size bolts go to the front drive shaft flange on the NP241. I had read somewhere that the size is M10x1.5 but I tried some and didn't seem to want to thread in.
Pretty sure its a M10 1.50 X 35 5/8 Hex head, try running a tap through it.
I will definitely give it a shot.
![]() Join Date: Feb 2014
Did you find the filler hose you needed? If not there is a member "Classic Heartbeat" that has a thread posted, stating he is will be selling these very soon. I saw his thread and remembered our conversation.
86 Chevrolet K10 350/SM465 Frankie SOLD 1995 GMC Yukon GT SOLD 1996 GMC Yukon GT 2010 Suburban 1500 4x4 5.3l/6L80e. Sold 2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e |
I will still need a new one most likely. I found an old one from a 20 gal tank but it is as hard as a rock so it needs replacing.
#15 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=684698
