08-24-2015, 02:37 PM | #1 |
Junior Member
1965 SWB Running Gear
Will the Running gear and disc break system off a 1974 Chevrolet bolt right up to the 1965 Frame? I bought a rusty 74 with all new running gear, posi rear end, disc breaks rebuilt 454 and turbo 400, I wanted to steel everything from this frame and bolt on to the 65.
Thanks Dan |
08-28-2015, 12:16 PM | #2 | |
Re: 1965 SWB Running Gear
Sam |
08-29-2015, 01:08 AM | #3 |
60-66 Nut
Yes, buying a complete donor truck as you did is probably the best way to go about upgrading your '65. There will be a few things you will need to change along the way, such as engine mounts and trailing arm mounts on the differential, but it is definitely doable.
